Call Detail Records Caller Id
How do you enable the 'src' (Caller ID) column in the Call Detail Records? It always displays as an empty string "". I couldn't find anything in the help files. Thank you.
If CallerID is supplied by Telco then this field is automatically filled in with that information.
(on outgoing calls this field holds the dialed number).
