Filedatetime
How do I find the date a file was last modified? Tried using VBS module with no luck.
Dim STRJobDate
STRJobDate = cstr(FILEDATETIME("c:\test.wav")
But all I get are VBS errors. what am I doing wrong?
Although FileDateTime() is supportd in VBA I'm not too sure if it is supported in VBScript. But you can use the FileSystemObject in VBS to get the same information (an much more...)
The code would be:
Dim fso, f, strDateCreated
Set fso = CreateObject("Scripting.FileSystemObject")
Set f = fso.GetFile("c:\test.wav")
strDateCreated = f.DateCreated
more information on FileSystemObject can be found at:
MSDN Help on FileSystemObject
and the above example was found in:
http://msdn.microsoft.com/library/default....datecreated.asp
