Guest u4910 Report post Posted 11/24/2009 08:09 PM I'm interested in the capabilities and configuration of digital lines. I'm mainly after getting the Called number (to route faxes and voice calls as needed) as well as other functionality. I would probably start out with a handfull of ISDN lines since I only need a few. Also what card is recommended with ISDN lines (need fax capability as well). Is there a handy document for this? All I see is the section on "T1/E1 ISDN Configuration" in the help. Thanks. Share this post Link to post
SupportTeam Report post Posted 11/24/2009 09:57 PM To support Fax on all channels you would need to get the DMV300B card (using the ML5 media load). http://www.dialogic.com/products/tdm_boards/media_processing/DMVB_Boards_DM3.htm Share this post Link to post
