Guest grzegorzj Report post Posted 11/25/2009 04:42 PM Hello Inband signalling file works correct in VG6 but in VG7 doesn`t. From log: 144800.506 5 [PBX]:InbandSignalConfig = C:\Program Files\VoiceGuide\conf\InbandSignaling_SiemensHiPath4000.txt 144800.522 5 ERROR v7.1.3615.29799 (2009-11-24 16:33:18.41) mainLoad INI Config : Odwołanie do obiektu nie zostało ustawione na wystąpienie obiektu. w .[1].() w ..(String sAppPath) Best Regards, Grzesiek Share this post Link to post
SupportTeam Report post Posted 11/26/2009 04:37 AM Please update system to this version of VG v7: [old link removed]and post traces from this version if you still encounter any issues with the Inband Signaling. Share this post Link to post
Guest grzegorzj Report post Posted 11/26/2009 08:14 AM On 11/26/2009 at 4:37 AM, SupportTeam said: Please update system to this version of VG v7: [old link removed]and post traces from this version if you still encounter any issues with the Inband Signaling. Now seems to be good. I will check this. Thank You. Share this post Link to post
Guest grzegorzj Report post Posted 11/26/2009 08:36 AM Hello, Inband signalling file is read by system but there is another error: 093053.180 6 3 2 Inband [*2011111524***] matched by pattern [[*][1-4]?????????[*][*][*]] 093053.180 6 3 2 Inband [inband_TOC] = [2] 093053.182 6 3 2 ERROR v7.1.3617.26571 (2009-11-26 14:45:42.40) Error_ScriptEventCode : Odwołanie do obiektu nie zostało ustawione na wystąpienie obiektu. w vgEngine.ScriptRunsStateMachine.‘(Int32 iLineId, Int32 iCode, String sCode, Int32 lParam1, Int32 lParam2, Int32 lParam3, String sParam1, String sParam2, String sParam3) w vgEngine.ScriptRunsStateMachine.(Int32 iLineId, Int32 crn, Int32 lCode, String sCode, Int32 lParam1, Int32 lParam2, Int32 lParam3, String sParam1, String sParam2, String sParam3) 093053.184 6 3 2 HangupCall, source=Error_ScriptEventCode, WorkModeScript=Running_Normal, yLineStateAppPov=[Connected], lPlayId=0, lRecId=0 093053.184 6 3 2 ScriptWorkingMode set Stopping, (called from HangupCall) Please give me some advice with it. Best Regards, Grzegorz Share this post Link to post
SupportTeam Report post Posted 11/26/2009 10:14 AM Please update system to this version of VG v7: [old link removed]and post traces from this version if you still encounter any issues with the Inband Signaling. Share this post Link to post
Guest grzegorzj Report post Posted 11/26/2009 10:33 AM Hi, In attachment there is log from VG7. 1126_1129_vgEngine.zip Share this post Link to post
SupportTeam Report post Posted 11/26/2009 11:48 AM Could you please .ZIP up and post the InbandSignaling_SiemensHiPath3000.txt file. It loos like one of the definitions in it (specifically the pattern [*][*]?*****????[*][1-4]) is incorrect and that is causing errors when trying to interpret the inband signaling data. Share this post Link to post
Guest grzegorzj Report post Posted 11/26/2009 12:01 PM Hi, Ok, zip with 2 files attached (I want to use 3000 or 4000 in some cases). InbandSignaling_SiemensHiPath3000.zip Share this post Link to post
SupportTeam Report post Posted 11/26/2009 12:27 PM in InbandSignaling_SiemensHiPath3000.txt file. change: ;3 digit station numbers, forwarded call - bluemedia zewnêtrznie 1 Pattern=[*][*][*]?*****????[*][1-4] RV=Inband_TOC,4,1,Inband_Calling,7,3,Inband_Called,10,4,Inband_Info,17,1 ;3 digit station numbers, forwarded call - bluemedia zewnêtrznie 2 Pattern=[*][*]?*****????[*][1-4] RV=Inband_TOC,3,1,Inband_Calling,6,3,Inband_Called,9,4,Inband_Info,17,1 to: ;3 digit station numbers, forwarded call - bluemedia zewnêtrznie 1 Pattern=[*][*][*]?*****????[*][1-4] RV=Inband_TOC,4,1,Inband_Calling,7,3,Inband_Called,10,4,Inband_Info,15,1 ;3 digit station numbers, forwarded call - bluemedia zewnêtrznie 2 Pattern=[*][*]?*****????[*][1-4] RV=Inband_TOC,3,1,Inband_Calling,6,3,Inband_Called,9,4,Inband_Info,14,1 Changes in Bold. The values of '17' are more then the length of the pattern... Share this post Link to post
Guest grzegorzj Report post Posted 11/30/2009 01:30 PM I changed this. Better this time. I will test it better. Share this post Link to post
SupportTeam Report post Posted 11/30/2009 08:22 PM Future releases of v7 will flag instances of inband definition errors in the logs, but will continue on with the call. Share this post Link to post
