Guest sss1019 Report post Posted 12/31/2009 09:22 PM My script gives the caller the option to leave a voicemail. After the caller is done recording their message and are silent, voiceguide is hanging up the call. I would like to do a little nicer orderly "hangup" by playing a sound file first then hanging up the call. I used the return statement as seen below on {1} goto [Play HouseMessage] on {2} goto [VoiceMail Box $RV[Get HouseCodeNumber]] return [Goodbye] on {timeout 0} goto [Goodbye] Here is part of what I see in the log file 6145748.64 6 rv replace end: [on {1} goto [Play HouseMessage] on {2} goto [VoiceMail Box 9999] return [Goodbye] on {3} goto [Play HouseMessage] ] 145748.64 6 FindVoicemailSysEntryPoint(VoiceMail Box 9999, return [G...,,) 145748.64 6 PutStuffOnReturnCallStack(Voicemail,Voicemail Box,,Goodbye) 145748.64 6 stack idx=1 Any help would be appreciated. Share this post Link to post
SupportTeam Report post Posted 12/31/2009 10:00 PM Which version of VoiceGuide are you using? You may need to modify the Voicemail scripts, changing the path in module [VmLmRec] from: on {silence} goto [VmLmHangup] to: on {silence} return Share this post Link to post
Guest sss1019 Report post Posted 01/02/2010 10:28 PM Which version of VoiceGuide are you using? You may need to modify the Voicemail scripts, changing the path in module [VmLmRec] from: on {silence} goto [VmLmHangup] to: on {silence} return Using version 5 with a way2call Hi-Phone Made the change that you suggested and it worked....but it caused another issue. Had vm set so that if a message was left, it would automatically call that person to let them know a message was left for them. If I make the change requested, the VM won't call me back. If I change it back so that on silence goto VmLmHangup, it will call me back and let me know a message was left. Tried it multiple times both ways with the same result each time. Share this post Link to post
SupportTeam Report post Posted 01/02/2010 11:26 PM If you want the messages forwarded as well then you should copy the module [VmLmHangup_ForwardLastMsg] from vmLmHangup.vgs, (call it say [VmLmHangup_ForwardLastMsg_LocalCopy]) and change the paths like this: on {silence} goto [VmLmHangup_ForwardLastMsg_LocalCopy] and in the [VmLmHangup_ForwardLastMsg_LocalCopy] modules then have path. on {success} return Share this post Link to post
