health4us Report post Posted 10/01/2003 09:16 AM I have input data into voiceguide and am now trying to query my database for this data.. the data i am querying is a 4 digit number... the number i input is right but voiceguide gives me an error message.. What does this message mean and how do i fix it please? thanks Matt 110900.59 7 callstate CONNECTED 66479,1,0 110900.59 7 WorkingModeTAPI@Connected= 110900.59 7 WorkingModeScript@Connected= 110900.62 0 dial callque delete id=7 110900.63 7 Live person answered, starting C:\Program Files\VoiceGuide\Scripts\recruitment\IncomingCalls\IncomingCall.vgs 110900.63 2 tr NewVgsVgm_Goto C:\Program Files\VoiceGuide\Scripts\recruitment\IncomingCalls\IncomingCall.vgs,,,,,0 110900.63 0 LoadedVgs_Find C:\Program Files\VoiceGuide\Scripts\recruitment\IncomingCalls\IncomingCall.vgs at idx=3 110900.63 7 cl NewVgsVgm_RunModule module not found: 110900.63 2 tr NewVgsVgm_Goto 1 110900.63 2 tr NewVgsVgm_Goto 2 110900.63 7 [QUERY CALLER ID] DB Query 110900.63 7 Jet mode used (To use ODBC mode specify ODBC Connect string) 110900.64 7 RVreplace start (strlen>100) 110900.64 7 About to execute Retrieve Operation [sELECT Title, Name, Surname, UKPhoneNumber, CallersName, CallStatus, LeadSource, CallSubject, Address1, Address2, Address3, City, County, Postcode, CallersEmail, CampaignName, CallersText, TrainingComputerId, AccessCode FROM NamesList WHERE PhoneNumber=01423325554] 110900.64 7 [QUERY CALLER ID] movelast err : No current record. 110900.64 7 [F.Enter Pin Code] Number Input 110900.64 7 [F.Enter Pin Code] Playing (enter-access-code.wav) 110900.68 7 PlaySoundStart ok [enter-access-code.wav] 110900.68 2 tr NewVgsVgm_Goto end 110902.98 7 wb(90033600) 110903.98 7 Play End line[7] (id=900336) 110903.98 7 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED 110905.69 7 dtmf 0 (66479,48,2) 110905.69 7 LsGetNbrsRxDigits 0 110905.70 7 [F.Enter Pin Code] Number Input 0 110906.63 7 dtmf 0 (66479,48,2) 110906.63 7 LsGetNbrsRxDigits 0 110906.63 7 [F.Enter Pin Code] Number Input 00 110907.07 7 dtmf 5 (66479,53,2) 110907.07 7 LsGetNbrsRxDigits 5 110907.07 7 [F.Enter Pin Code] Number Input 005 110907.55 7 dtmf 1 (66479,49,2) 110907.55 7 LsGetNbrsRxDigits 1 110907.55 7 [F.Enter Pin Code] Number Input 0051 110913.50 7 LsGetNbrsRxDigits EV_TIMEOUT_ENTERDATA 110913.50 7 fn PlaySoundStartNumbers record-number-youhaveenteredthefollowingnumber.wav, record-number-press1ifcorrect.wav, 0051, Digits 110913.50 7 twcal PlaySayNumber record-number-youhaveenteredthefollowingnumber.wav, record-number-press1ifcorrect.wav, 0051, , 1 110913.54 7 PlaySoundStartNumbers ok 110915.35 7 dtmf 1 (66479,49,2) 110915.35 7 LsGetNbrsPlayConfirm 1 110916.35 7 PlaySoundStop ok 110916.35 7 path {0051} not found 110916.36 7 dtmf 1 (66479,49,2) 110916.37 7 [s/F.Search Pin Code] DB Query 110916.37 7 Jet mode used (To use ODBC mode specify ODBC Connect string) 110916.38 7 RVreplace start (strlen>100) 110916.38 7 About to execute Retrieve Operation [sELECT Title, Name, Surname, UKPhoneNumber, CallersName, CallStatus, LeadSource, CallSubject, Address1, Address2, Address3, City, County, Postcode, CallersEmail, CampaignName, CallersText, TrainingComputerId FROM NamesList WHERE AccessCode=0051] HERE IS THE ERROR 110916.38 7 ERROR 5.1.2055 OpenRecordset: 3464:Data type mismatch in criteria expression. 110916.38 7 [F. Get a Pin Code] Playing 110916.39 7 tts generate start[wrong access code.. press 1 to try again] 110916.48 7 tts generate end 110916.49 7 [F. Get a Pin Code] Playing (C:\Program Files\VoiceGuide\system\tts7.wav) 110916.50 7 PlaySoundStart ok [C:\Program Files\VoiceGuide\system\tts7.wav] 110916.50 7 RunModule PLAY end 110920.70 7 wb(91617900) 110921.71 7 Play End line[7] (id=916179) 110921.71 7 LsPlayMsg EV_PLAY_FINISHED 110931.62 7 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE 110931.62 7 Hanging up call... [Hangup Module] 110931.62 7 RecSoundStop ok 110931.62 7 PlaySoundStop ok 110931.62 7 fnHangupCall end 110931.66 7 linedevstate 2048 0 0 110931.67 7 callstate IDLE 66479 0 0 110931.67 7 WorkingMode@Idle= 110931.69 7 tapi Reply (LineEvReply) ok 66497 0 110932.62 7 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE 110932.62 7 ReinitTelephony due to IDLE start 110932.62 7 tapic lineDeallocateCall(MainCall:66479) 0 110932.77 7 lineOpen(7) => 0 110932.77 7 Waiting for a call... 110932.77 7 lineOpen(7)LineHandle=65557 Share this post Link to post
health4us Report post Posted 10/01/2003 09:20 AM Is it possible to update 2 database records/tables in the same access database using only 1 database module? If so do i just repeat this code twice and change the relevant table names etc? UPDATE NamesList SET CallStatus='LISTENING TO RECORDED CALL 1', LastUpdated='$RV_STARTTIME' WHERE AccessCode='$RV[GetClientRecord_19_1]' Thanks Matt Share this post Link to post
health4us Report post Posted 10/01/2003 09:23 AM Sorry i asked 2 questions at once on 2 messages in error... please can you take the time to answer both... thanks Matt Share this post Link to post
SupportTeam Report post Posted 10/01/2003 11:31 AM "Data type mismatch in criteria expression" error The error description pretty much says it all... The error is generated by MS Access - there should be more info on this error in MS Access Help file, or you may search for "Data type mismatch in criteria expression" on http://www.google.com.au/advanced_group_search?hl=en Is it possible to update 2 database records/tables in the same access database using only 1 database module? VoiceGuide just passes the contents of the SQL statement to the database, so it all depends on whether the database accepts such a statement or not... best to consult the databases Help file on this one as well. Share this post Link to post
