Call Path Flow
When implementing v7 for outbound message system for hospital, what would be best approach to take when moving from one module to the next, without user interaction. (ie: Module 1 - wav file detailing who is calling; hospital name, Module 2 - wav file detailing who the call is looking for; Patient's name ) It would not be until module four or five, that the user would have any interaction.
The wav files would be recorded in a studio, in individual words / phrases. The modules would be mixing and matching, generally before user interaction.
What are your thoughts? Thank you
In most cases you would use a "Timeout 0" path, or a "Success" path in some other modules.
If you can post your script along with a description of what you want to achieve then we can assist in making modifications to it and posting the modified copy back here.
You can also play multiple sound files in same Play module by just specifying the WAV files one after another and separating them with a comma.
eg:
a.wav,b.wav,c.wav
