Initialize A Variable To Zero 0
Hello,
In a Evaluate Expression module I have in the Expression details section the number zero:
0
And in the Assign result ... I have Counter1
It does not work I mean it hang up but I notice that if I change the zero 0 for a 1 than it works.
Why isn't it possible to initialize a counter at 0? The example in the Help under Evaluate Expression show that it is possible.
This is what I get in the trace:
30968 5 [init Retries Counter1] Evaluate 0
30984 5 Eval Expr result:[0]
30984 5 Hanging up call...
30984 5 TimeoutSet 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
Thank you
When an assignment of a value of 0 is made then VoiceGuide will branch down the "False" path (or "Fail" path) - and if the "False" path is not defined it will then hangup the call.
Defining the "False" path in [init Retries Counter1] module should fix the problem...
