Using Only 4 Channels On E1 Trunk
Roberto asked:
My E1 trunk can carry 30 telephone calls and now use a Dialogic D/300JCT card, then if I will buy Voiceguide v7 for 4 lines in my E1 and in the future buy more VoiceGuide licenses. No problem with the integration?
We have a D/300JCT-1E1.
Most PBXs/Switches allow partial enabling of channels on an E1 line, but some will only function if all 30 channels are enabled (or 10 or 20 depending on their configuration).
To verify operation you can try just using the Evaluation version and specifying 4 channels in VoiceGuide's Config.xml file, and see if the calls are correctly carried on this trunk while only a partial number of channels is opened/enabled.
Which PBX/Switch is supplying the E1 trunk?
