Guest holziusa Report post Posted 02/10/2010 12:56 AM demo v7.1.3691.27821 Dial and Conference vg crashes when the call is being dialed on the second line, this also happens when i use flash hook transfers i am in test mode so the script is simple, call into sound module, press two, goto transfer module "dialout/conferenced/anounced", caller hears moh,vg dials out on designated line (tried several), call is placed to hard line (tried cell phone as well) vg crashes leaves lines in off-hook state, have to restart dialogic server to start over. attached logs error message "no event issued after dial" Share this post Link to post
SupportTeam Report post Posted 02/10/2010 02:53 AM Please post the vgEngine and ktTel traces from your system showing system startup and the attempted Dial And Conference call. (Please .ZIP up traces before posting). Share this post Link to post
Guest holziusa Report post Posted 02/10/2010 04:09 AM Please post the vgEngine and ktTel traces from your system showing system startup and the attempted Dial And Conference call. (Please .ZIP up traces before posting). thought i zipped up the first time Share this post Link to post
SupportTeam Report post Posted 02/10/2010 05:33 AM Have just tried this on our test system and it works fine. What model Dialogic card are you using on your system? Only partial ktTel trace was supplied so we cannot see if system configuration was all ok. Can you please post a ktTel showing system startup. (you can stop VG, delete all log files, then start VG and then post the created ktTel). Which SU version of the SR6.0 drivers is installed on system? (see Help->About in Dialogic DCM) Share this post Link to post
Guest holziusa Report post Posted 02/10/2010 06:26 AM thanks 4 follow up now thta you mentioned it vg only runs on 6.0 and up i think i just came over from a app called ivm which i just reverted the install back to R5.1.1 prior that i used 6.1 which did not work for me either pardon my overlook which now i guess i will install R6.0 but I dont have any service updates i have a oem copy came with the board not sure if your online version is more current have to look at the build i removed full path info and phone numbers from zip D/4PCI-U Dialogic R5.1.1 with SU149 Share this post Link to post
SupportTeam Report post Posted 02/10/2010 09:07 AM Please download the Dialogic drivers from our WWW downloads page. Uninstall your current Dialogic drivers. Do not save any settings. Then restart system and delete the entire C:\Program Files\Dialogic directory. The install the Dialogic drivers downloaded from our WWW downloads page. Share this post Link to post
SupportTeam Report post Posted 02/10/2010 09:09 AM BTW: D/4PCIU cards do not support "Dial and Conference". From http://www.voiceguide.com/vghelp/source/html/modxfer.htm : Dial and Conference General Notes: The D4PCIUF and D/4PCIUS cards do not support "Dial and Conference". You need a JCT or DMV series card (eg. D/41JCT, D/120JCT, DMV160 etc.), or any T1/E1 Digital cards (eg. D/240JCT, DMV600B etc.) Share this post Link to post
