State Display
I used the standard 4-port Dialogic board varieties without a problem. I recently installed the 12-port DIALOGIC D/120JCT-LS VOICE CARD.
I switched the config file to the 12-port sample included after renaming it "config.xml"
I am getting a "State display disabled" even though the board seems to work fine, but I am uncomfortable beeing in the dark like that.
Any idea how to make it display the familiar "Waiting for a call" ?
In v6 the main apps' state display does not show the live line status if more then 8 lines are used.
The scripts etc. still run, it's just that the main programs state window is not updated with the state information.
In newer v6 releases you can use the vgStatusMonitor.exe app to monitor the line status. vgStatusMonitor.exe is installed in the VoiceGuide directory.
