Guest jfsauriol Report post Posted 02/18/2010 06:46 PM Hello! I have VG7 ( 4 lines) with dialer and use a Dialogic D/4PCI-U cards with régular copper line. I want to switch to a VoIP provider for my phone lines and increase to 8 lines. Wath kind of hardware and software did i need? Share this post Link to post
SupportTeam Report post Posted 02/18/2010 07:33 PM You would need to remove the Dialogic card and uninstall the SR6.0 drivers, and then install the Dialogic HMP drivers. Then you will need to uninstall VoiceGuide,and then install int again but this time select 'VoIP' as the install type. Share this post Link to post
Guest jfsauriol Report post Posted 02/18/2010 11:43 PM On 2/18/2010 at 7:33 PM, SupportTeam said: You would need to remove the Dialogic card and uninstall the SR6.0 drivers, and then install the Dialogic HMP drivers. Then you will need to uninstall VoiceGuide,and then install int again but this time select 'VoIP' as the install type. No hardware needed? Share this post Link to post
SupportTeam Report post Posted 02/19/2010 07:54 AM Correct. No hardware is needed. The HMP drivers send/receive VoIP packets over the computers/servers network connector. Share this post Link to post
