Guest visualbench Report post Posted 02/22/2010 08:22 AM I am using 2 telephone lines of same operator for the Dialogic card D/4 PCI. Channel One(line one) is working well and tsf file generated as channel one as main.Same tsf file not working for the Channel 2(line 2) so unable to dial from both the line simultaneously. Please advise how to use Voice Guide6.0 to solve this problem. Share this post Link to post
SupportTeam Report post Posted 02/22/2010 07:23 PM Have you tried setting the tone definitions using VoiceGuide's ConfigLine.xml file? Please have a look at the ConfigLine.xml and read: http://www.voiceguide.com/vghelp/source/html/disconnectiondetect.htm Share this post Link to post
Guest visualbench Report post Posted 02/23/2010 04:39 AM On 2/22/2010 at 7:23 PM, SupportTeam said: Have you tried setting the tone definitions using VoiceGuide's ConfigLine.xml file? Please have a look at the ConfigLine.xml and read: http://www.voiceguide.com/vghelp/source/html/disconnectiondetect.htm Yes,I have set all the tone definitions otherwise Line1 should not work.Please find my configline.xml file as attachment. Please note that line 1 telephone number is different than line 2,but operator is same ConfigLine.xml Share this post Link to post
SupportTeam Report post Posted 02/23/2010 05:15 AM Could you please post a copy of VoiceGuide's Debug Printout which captures the two outgoing call, this will allow us to see what happened Debug Trace files are created in VG's \log\ subdirectory. When posting traces/scripts please .ZIP them up and post them as attachments. What is the tone that you are trying to detect? The disconnect tone? or some other tone? Share this post Link to post
Guest visualbench Report post Posted 02/24/2010 06:06 AM On 2/23/2010 at 5:15 AM, SupportTeam said: Could you please post a copy of VoiceGuide's Debug Printout which captures the two outgoing call, this will allow us to see what happened Debug Trace files are created in VG's \log\ subdirectory. When posting traces/scripts please .ZIP them up and post them as attachments. What is the tone that you are trying to detect? The disconnect tone? or some other tone? Please find attachment for VoiceGuide's Debug Printout. When dialing through Line2,Always it is being detected as Answer machine when caller lifts the phone and say Hello ,it was hangup. where as everything is properly working in line1. VG_Logs.zip Share this post Link to post
SupportTeam Report post Posted 02/24/2010 11:34 AM So the actual issue is that outgoing calls made on line 2 are always classed as if they are being answered by an answering machine, correct? Have you tried swapping the lines around to see if the this is realted the the telephone line or whether this is related to the port on the Dialogic card? Share this post Link to post
Guest visualbench Report post Posted 02/25/2010 02:40 PM On 2/24/2010 at 11:34 AM, SupportTeam said: So the actual issue is that outgoing calls made on line 2 are always classed as if they are being answered by an answering machine, correct? Have you tried swapping the lines around to see if the this is realted the the telephone line or whether this is related to the port on the Dialogic card? swapped the telephone lines and found the issue is related to telephone line. I am using two telephone direct lines(with out any EPBx),one telephone line is working in any port of Dialogic card and other telephone line is not working in any port. please note that two telephone lines phone number is not same. Share this post Link to post
SupportTeam Report post Posted 02/25/2010 06:50 PM Most likely the phone line that is always returning Answering Machine connection has a poorer connection quality then the phone line that is working. Please see: http://www.voiceguide.com/vghelp/source/html/detectcallanswer.htm Share this post Link to post
