Problems With Board Dialogic D/300Sc-E1 And Voiceguide
Good afternoon!
We had a problem with adjustment of program VoiceGuide.
The version of the program 6.0.0.3391, the device - Dialogic D/300SC-E1.
We think to get your product, but we can not adjust yet, whether to check up it approaches for us.
You could not help with program options?
Our stream Е1 - ISDN.
What options to us need to be asked the provider?
Log.zip
It looks like you have the E1 ISDN link working on this system, but have problems placing outbound calls. Is this correct?
Are you able to place calls into the system and can caller hear the system answer the incoming call?
If yes then please post the 'tw' trace (.ZIPed) capturing the incoming call.
172839.427 002 ocxfn LineMakeCall(linedev=2, hcall=0, 84959847810, callprog=DX_PAMDOPTEN, timeout=60, params:[0,0,cid=,]) chdev=3, dtidev=2
172839.427 002 makecall protocol is: ISDN
172839.557 002 outgoing cid is blank. SetCallingNum not called.
172839.557 002 gc makecall defsrc cc used. Non DM3 card
172839.557 002 cc.BC_xfer_cap=BEAR_CAP_SPEECH
172839.557 002 cc.BC_xfer_mode=ISDN_ITM_CIRCUIT
172839.557 002 cc.BC_xfer_rate=BEAR_RATE_64KBPS
172839.557 002 cc.usrinfo_layer1_protocol=ISDN_UIL1_G711ULAW
172839.557 002 cc.usr_rate=ISDN_NOTUSED
172839.557 002 cc.destination_number_type=NAT_NUMBER
172839.557 002 cc.destination_number_plan=ISDN_NUMB_PLAN
172839.557 002 cc.destination_sub_number_type=OSI_SUB_ADDR
172839.557 002 cc.origination_number_type=NAT_NUMBER
172839.557 002 cc.origination_number_plan=ISDN_NUMB_PLAN
172839.557 002 cc.origination_sub_number_type/origination_sub_number_plan=OSI_SUB_ADDR/ISDN_NOTUSED
172839.557 002 cc.facility_feature_service=ISDN_NOTUSED
172839.557 002 cc.facility_coding_value=ISDN_NOTUSED
172839.557 002 gc gc_MakeCall(84959847810) call
172839.577 002 gc gc_MakeCall(2, [84959847810], 60) ok
172839.577 002 call progress detection not enabled. We'll wait till after connect
172839.677 002 eng gc_GetMetaEventEx returned. lEvtHandle=0, iDev=2, lEvtType=2086, pEvtData=0x966a4f0, lEvtDataLen=28
172839.677 002 ev metaevent: cclibid=0x2, crn=0x2008022, evtdatap=0x966a4f0, evtdev=0x2, evtlen=0x1c, evttype=0x826, extevtdatap=0x0, flags=0x1, linedev=0x2, magicno=0xbad012fb, rfu1=0x2, usrattr=0x192d00 (usrattr=hli)
172839.677 002 ev GCEV_DISCONNECTED
172839.687 002 gc GCST_DISCONNECTED status gc:0:[success], cc_err=0 cclibid=0
172839.697 002 ResultInfo gcValue=1286(0x506) gcMsg=[Event caused by call control library specific failure] ccLibId=2 ccLibName=[GC_ISDN_LIB] ccValue=[0x264|GCRV_CCLIBSPECIFIC|event caused by cclib specific failure] ccMsg=[invalid information element] additionalinfo=
