mehdi_h Report post Posted 03/12/2010 06:32 PM Hi, I have experienced something that I never get before. My VG system connected on externat mysql database does not start anymore. When I look at the logs I see : "ERROR v7.1.3699.20074 (2010-02-16 11:09:08.70) DoWorkFindCall stage1 : The SELECT would examine more than MAX_JOIN_SIZE rows; check your WHERE and use SET SQL_BIG_SELECTS=1 or SET SQL_MAX_JOIN_SIZE=# if the SELECT is okay" Please could have a loog and let me know what's the probleme? Tkx Mh 0312_1928_vgEngine.txt Share this post Link to post
mehdi_h Report post Posted 03/22/2010 10:32 AM Hi, any help please, Thank you Share this post Link to post
SupportTeam Report post Posted 03/22/2010 10:48 AM How many entries do you have loaded in the PortToUse ad OutDialQue tables? Have you tried adding SET SQL_BIG_SELECTS=1; to the OutDialQue_SqlPrefix field, making OutDialQue_SqlPrefix: OutDialQue_SqlPrefix=SET SQL_BIG_SELECTS=1; SELECT Share this post Link to post
mehdi_h Report post Posted 03/23/2010 10:00 PM Hi, In the database I have arround 15OOO entries in the Callque table. As I have 30 lignes , in the Porttouse table is then 15000* 30 entries. I have set that in the config.xml file : <OutDialQue_SqlPrefix>SET SQL_BIG_SELECTS=1; SELECT</OutDialQue_SqlPrefix> is this correct ? Thk MH Share this post Link to post
SupportTeam Report post Posted 03/24/2010 08:30 PM I have set that in the config.xml file : <OutDialQue_SqlPrefix>SET SQL_BIG_SELECTS=1; SELECT</OutDialQue_SqlPrefix> is this correct ? Yes. Is the dialer query now working? Can you post traces? Share this post Link to post
mehdi_h Report post Posted 03/25/2010 04:02 PM Actually I don't know really what happens. as I have two issues logged for now and I don't know what is the conseuqnece of wich cause. For exmaple, I have experience that only 6 or 7 lines of my system were calling. All aothers were "waiting for call" My other issue topic is : "Strange Behaviour In Line Status Panel" anyway here are the last logs. thank You Mh Share this post Link to post
SupportTeam Report post Posted 04/30/2010 01:28 AM No logs were attached. If you still have any issues pleae start a new thread/topic. Share this post Link to post
