Internet - Voiceguide Examples
I am looking for examples (anything) on how voiceguide can work with the internet.
Thanks,
-Brandon
Actually I am looking for a way to play the voicemail files onto the internet. Is there a way to automate this?
Thanks again,
-Brandon
Once the streaming audio broadcast server is set up using ShoutCast (http://www.shoutcast.com/) or RealAudio etc then VoiceGuide can be used to supply the sound files to be broadcast by it...
A Run Program module can be used to specify what files should be broadcast, eg: if using ShoutCast this involves just starting Winamp (with the SHOUTcast Source Plug-in for Winamp) and using it to play the file to the server, and the server will then broadcast the audio...
couldn't he use the ftp feature to upload the messages and a little script on his web host to have a web-based admin area to review and delete the messages?
