Seperate Email After Hang Up
Sir Good day! How can I seperate the email "if it is english or arabic" after hang up?
See my module attached, you see after the caller choose any language, then after hang up load another script, they need to go to
email for arabic module?Can you fix my module for my future refernece.Thanks a lot!!
Attached:
AfterHangupEmail.zip
Please see the new AfterHangupEmail.vgs script.
The script now starts at module "Lang Switch". That module goes to different Email module based on what selection caller made beforehand.
vgEngine trace shows the script runs fine, and switches to the right email module, and the email send is attempted, but then your SMTP server replies with:
Mailbox unavailable. The server response was: 5.7.0 Your server IP address is in the SpamHaus SBL-XBL database, bye
So looks like you should try sending your emails though a different email server, or have a look at your current SMTP server to see why it is replying with this message...
172806.562 6 1 1 RunModule start Evaluate, [Lang Switch], iModuleIdx=81, previous: vgm=3, vgs=6
172806.562 6 1 1 state [Lang Switch] Evaluate [$RV[Choose Language]]
172806.562 6 1 1 rv replace start: [$RV[Choose Language]]
172806.562 6 1 1 rvns: [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[scriptPath]{C:\Documents and Settings\Note 2\Desktop\Test\}[scriptsPath]{C:\Documents and Settings\Note 2\Desktop\Test\}[$RV_STARTTIME]{2553-05-05 17:27:57}[$RV_DEVICEID]{1}[DlgcVoice]{dxxxB1C1}[DlgcNetwork]{dxxxB1C1}[$RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[scriptPath]{C:\Documents and Settings\Note 2\Desktop\Test\}[scriptsPath]{C:\Documents and Settings\Note 2\Desktop\Test\}[$RV_CIDNUMBER]{042807639}[Caller_Input]{"042807639"}[Caller]{042807639}[Choose Language]{2}[EN_Input]{"2"}[EN]{2}[Lang]{2}[Hangup Source]{Hangup Module}[CallHangupTime]{2553-05-05 17:28:06}
172806.562 6 1 1 rv replace end: [2]
172806.562 6 1 1 eval[2]
172806.562 11 db PerformWork_RunCoreSql cmd_CoreSql.ExecuteNonQuery returned
172806.562 6 1 1 CreateInstance ScriptControl objSC is: [system.__ComObject]
172806.562 6 1 1 rvns add [Lang Switch_Input]{2}
172806.562 6 1 1 rvns add [Lang Switch]{2}
172806.562 6 1 1 Eval Expr result:[2]
172806.562 6 1 1 path {2} found (at offset 27)
172806.562 6 1 1 FindNextVgmTitleInPathList: next module title is=
172806.562 6 1 1 t timer clear (force=False)
172806.562 6 1 1 RunModule start Send Email, , iModuleIdx=1, previous: vgm=81, vgs=5
172806.562 6 1 1 state Send Email
English
Caller Number : $RV_CIDNUMBER
172806.562 6 1 1 rvns: [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[scriptPath]{C:\Documents and Settings\Note 2\Desktop\Test\}[scriptsPath]{C:\Documents and Settings\Note 2\Desktop\Test\}[$RV_STARTTIME]{2553-05-05 17:27:57}[$RV_DEVICEID]{1}[DlgcVoice]{dxxxB1C1}[DlgcNetwork]{dxxxB1C1}[$RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[scriptPath]{C:\Documents and Settings\Note 2\Desktop\Test\}[scriptsPath]{C:\Documents and Settings\Note 2\Desktop\Test\}[$RV_CIDNUMBER]{042807639}[Caller_Input]{"042807639"}[Caller]{042807639}[Choose Language]{2}[EN_Input]{"2"}[EN]{2}[Lang]{2}[Hangup Source]{Hangup Module}[CallHangupTime]{2553-05-05 17:28:06}[Lang Switch_Input]{2}[Lang Switch]{2}
172806.562 6 1 1 rv replace end: [English
Caller Number : 042807639]
172806.562 6 1 1 rv add {kiosk@solutionsurce.ae}
172806.562 6 1 1 rv add {AR}
172806.562 6 1 1 rv add {EnglishCaller Number : 042807639}
172806.562 6 1 1 rv add {}
172806.562 6 1 1 email to: kiosk@solutionsurce.ae
172806.562 6 AddEmailToSend from:info@note.ae|, to:kiosk@solutionsurce.ae, cc:, bcc:, reply:info@note.ae, subj:AR, att:, usertoken:(<to>kiosk@solutionsurce.ae</to><subject>AR</subject><guid>7ae75e3f-252e-484b-84c9-df0bb2ea8a2f</guid>) smtp:mail.solutionsource.ae|25 timeout:1800sec
172806.562 6 SmtpClient created ok
172806.562 6 .Host=mail.solutionsource.ae .Port=25 .EnableSsl=False sCredentialUserName=[kiosk]
172806.562 6 SmtpClient clientEs configured ok
172806.562 6 email send start <to>kiosk@solutionsurce.ae</to><subject>AR</subject><guid>7ae75e3f-252e-484b-84c9-df0bb2ea8a2f</guid>, timeout=1800sec
172806.562 6 1 1 email queued for sending.
172815.046 4 email send error. <to>kiosk@solutionsurce.ae</to><subject>AR</subject><guid>7ae75e3f-252e-484b-84c9-df0bb2ea8a2f</guid> System.Net.Mail.SmtpFailedRecipientException: Mailbox unavailable. The server response was: 5.7.0 Your server IP address is in the SpamHaus SBL-XBL database, bye
at System.Net.Mail.SendMailAsyncResult.End(IAsyncResult result)
at System.Net.Mail.SmtpTransport.EndSendMail(IAsyncResult result)
at System.Net.Mail.SmtpClient.SendMailCallback(IAsyncResult result)
Yes. Traces show problems is with the SMTP (email) server not accepting email send requests from your IP address.
