Guest notes Report post Posted 05/09/2010 01:08 PM Sir Good Day, see my attached script and database. The script not taking the data from the database what do you think the problem?Im Using Access2007 and VG 6.0v Attached: 0509_1213_vgEngine.zip Share this post Link to post
SupportTeam Report post Posted 05/10/2010 01:07 AM In your SQL query one of the fieldnames is the same as one of the reserverd keywords. You can try putting brackets around the FieldName in the SQL queries, but it's best to just change the database's column names to not use a reserved keyword for any of the columns. In your case the table CIdlanguage has a column named: Langauage Change the column name to soemthing else (eg: CallersLang) and amend the SQL queries in the script appropriately. Share this post Link to post
SupportTeam Report post Posted 05/10/2010 01:15 AM Alos the SQL query in module VehicleData is wrong. The $RV is missing an end bracket Right now you have: SELECT VehicleBrand, VehicleType, VehicleColor, ExpireDate, Email1 FROM (AccountFile) WHERE DriverID=$RV[GetDriverNumber; change $RV[GetDriverNumber; to $RV[GetDriverNumber]; Share this post Link to post
Guest notes Report post Posted 05/10/2010 06:05 AM Quote In your SQL query one of the fieldnames is the same as one of the reserverd keywords. You can try putting brackets around the FieldName in the SQL queries, but it's best to just change the database's column names to not use a reserved keyword for any of the columns. In your case the table CIdlanguage has a column named: Langauage Change the column name to soemthing else (eg: CallersLang) and amend the SQL queries in the script appropriately. Good Day Sir, what do you mean the same as one of the reserved keywords? May I know Sir what fieldname you mention. By the way Thanks because I forgot to put bracket. Share this post Link to post
SupportTeam Report post Posted 05/11/2010 02:03 AM the table CIdlanguage has a column named: Langauage Change the column name to something else (eg: CallersLang) and amend the SQL queries in the script appropriately. Langauage is a reserved word. Share this post Link to post
Guest notes Report post Posted 05/11/2010 05:52 AM Sir there no other way Sir instead of changing the field name from my database? Share this post Link to post
SupportTeam Report post Posted 05/13/2010 07:09 AM You can try putting brackets around the FieldName in the SQL queries. ie: replace Language with: [Language] wherever you see Language in your SQL queries. Share this post Link to post
