Guest fsoudbakhsh Report post Posted 05/13/2010 12:38 AM Hello, I am building my prototype ISDN system to works with VG. please see attached file the way I think this system will be put together. please see attached my ISDN system structure drawing. the only thing I don't know is, how VG can make conference call between ISDN card and Analog card? Do I need a terminal? or it does conference call via PC mother board? please also note I will use 642746-001**INTEL**ISDN Phone Card ISA-16 w/ DSP Board. would VG works with this board? Thanks ISDN system structure.zip Share this post Link to post
SupportTeam Report post Posted 05/13/2010 04:38 AM Not sure want the "642746-001" code stands for, but if this is an ISA card then this is a very old card, and we would not support using this card for an application which involves bridging calls to and analog card. If you want to bridge calls between digital and analog cards then you would need to use VoiceGuide v7, and current model Dialogic cards. Look at using the "JCT" series or the "DMV" series cards. Share this post Link to post
