Voicemail Password On Hotel System
I am currently installing a voicemail system in an hotel environment. I need the password to be removed so that voicemail retrieval can be done without a guest having to enter a password to listen to their messages. Could support please indicate how I may achieve this? Thanks.
The voicemail scripts in VoiceGuide's /system/vm/ subdirectory need to be edited and the module that asks for password (and subsequently verifies the entered PIN number) removed.
Suggest you make a backup of the voicemail scripts before editing them.
I would like to use the variable $RV[inband_Calling] to automatically login to the correct mailbox.
If $RV[inband_Calling] is [100] then mailbox 100 must login and VmMmMsgCountCalls must then
continue and let the user know how many calls they have.
The question is how/where do I modify the VBS scripting to bypass the manual (VmLoginAskVmb)
and using the variable result, $RV[inband_Calling], continue with the script.
Have a look at the attached modified vmLogin.vgs
The changes are:
1.
In module [VmLoginStart] this VBScript line:
sNewRv = sNewRv & "[VmbId]{}[VmbLoginIntro]{none}"
was changed to:
sNewRv = sNewRv & "[VmbId]{$RV[inband_Calling]}[VmbLoginIntro]{none}"
2.
The path leaving module [VmLoginStart] is now:
on {Success} goto [VmMmMsgCountsCalc]
so the modules VmLoginAskVmb, VmLoginAskPin and VmLoginCheckPin are just bypassed.
Try just using the attached script and see if this works as you need it to work.
