Guest notes Report post Posted 05/20/2010 08:44 AM Sir Good day, I want to know the module of VBS and RUN module, even I try to look example on the scipt from the voiceguide,still im confuse.Even I try to read the help content still the same, hope can you provide me sample script,even just only small script using the VBS and RUN module. i just want to use this for my set of references,hope you really understand and you not give me a link to other site,just only simple script. Thanks hope for you good response Thanks!! Share this post Link to post
SupportTeam Report post Posted 05/20/2010 09:42 AM Have you looked at the "Credit Card" demo script that is installed with VoiceGuide? That script consists of a series of GetNumber modules, and a VBScript module which saves the information user entered into a text file. In same script there is a module titled "OLD Save Data to File" which is a Run Program module which shows another approach that can be used to save data to a text file. Share this post Link to post
