Vbs Script
Sir Good day, I want to know the module of VBS and RUN module, even I try to look
example on the scipt from the voiceguide,still im confuse.Even I try to read the help content
still the same, hope can you provide me sample script,even just only small script using the
VBS and RUN module. i just want to use this for my set of references,hope you really understand
and you not give me a link to other site,just only simple script. Thanks hope for you good response
Thanks!!
Have you looked at the "Credit Card" demo script that is installed with VoiceGuide?
That script consists of a series of GetNumber modules, and a VBScript module which saves the information user entered into a text file.
In same script there is a module titled "OLD Save Data to File" which is a Run Program module which shows another approach that can be used to save data to a text file.
