Record Message
Good Day! Sir on message recording, can I change the bitrate, simpling rate, format for recording
This is possible, and is right now available in a custom version of VoiceGuide v7.
The default format used by VG v7 (8kHz ULaw/ALaw) however usually gives best results for human voice recordings made from telephone lines. What other format would you like to use and why?
Regarding to change the format and bitrate for audiio file in mailbox, not the audio file for the system,its audio file on the script after the recording message of the caller
You are referring to just the sound file that is played after the message is recorded?
Please explain in more detail what you require. What other format would you like to use and why?
