Announced 3way Call Transfer And Timeout Delay
I'm using VG 5.0 right now and am having some trouble finding out how to modify the timeout delay when making a 3 way announced transfer. The help file makes mention of a timeout path in "Announced Modules", but I could not find any such modules that would affect the timeout once such a path was put in.
Also, when VG makes a call to my phone, it begins to play the announcement as soon as it has finished dialing. Is it supposed to play only when voice is detected?
I am using a Dialogic D41H board.
Thanks to any help offered.
Are you referring to the max time for which the "Call from [Caller ID], please press 1 to accept call.." message is repeated?
This time is settable in VG.INI file, section [PBX] entry "AnnouncedTransfersMaxWaitTime"
The value specified is in seconds and the default setting is 30 seconds.
Does it play the message itself, or the announcement to accept the call?
Here's a copy of the log. It just starts and continues to loop even before I answer the phone.
Any help would be appreciated. Thx!
013241.00 6 [introduction] Playing
013241.00 6 tts generate start[For Sales and Customer Service, please press One. For Accounting, please press Two. To make an online payment, please press Three. For Contact Information, please press Four.]
013242.63 6 tts generate end
013242.63 6 [introduction] Playing (C:\Program Files\VoiceGuide\system\tts6.wav)
013242.66 6 PlaySoundStart ok [C:\Program Files\VoiceGuide\system\tts6.wav]
013242.66 6 RunModule PLAY end
013245.01 6 dtmf 1 (49,2)
013245.01 6 LsPlayMsg 1
013245.06 6 PlaySoundStop ok
013245.07 6 [sales] Playing
013245.09 6 tts generate start[Please wait wile your call is being transferred.]
013245.65 6 tts generate end
013245.65 6 [sales] Playing (C:\Program Files\VoiceGuide\system\tts6.wav)
013245.67 6 PlaySoundStart ok [C:\Program Files\VoiceGuide\system\tts6.wav]
013245.67 6 RunModule PLAY end
013248.66 6 wb(68635000)
013248.71 6 Play End line[6] (id=686350)
013248.71 6 LsPlayMsg EV_PLAY_FINISHED
013248.72 6 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE
013249.14 6 LsXferStart EV_TIMEOUT_READYTOBEGINTRANSFER
013249.16 6 [sales] Announced Conference to 0000000000 (Generate)
013249.18 6 tapic lineGenerateDigits(66176,!,0) => 0
013249.87 6 generate LINEGENERATETERM_DONE
013250.79 6 LsXferStart EV_TAPI_GENERATE
013251.79 6 LsXferPlayVts EV_HOOKFLASHFINISHED
013251.82 6 tapic lineGenerateDigits(66176,0000000000,0) => 0
013253.31 6 generate LINEGENERATETERM_DONE
013254.22 6 LsXferPlayVts EV_TAPI_GENERATE
013254.22 6 fn PlaySoundStartNumbers TsfrCallFrom.wav, TsfrAskAccept.wav, 1111111111, Digits
013254.23 6 twcal PlaySayNumber C:\Program Files\VoiceGuide\system\voice\TsfrCallFrom.wav, C:\Program Files\VoiceGuide\system\voice\TsfrAskAccept.wav, 9054799301, , 1
013254.35 6 PlaySoundStartNumbers ok
013309.66 6 wb(69494211)
013309.71 6 Play End line[6] (id=694942)
013309.72 6 LsXferPlayAnn EV_PLAY_FINISHED
013309.72 6 LsXferPlayAnn EV_TIMEOUT_REPLAYMSG
013309.72 6 fn PlaySoundStartNumbers TsfrCallFrom.wav, TsfrAskAccept.wav, 1111111111, Digits
013309.72 6 twcal PlaySayNumber C:\Program Files\VoiceGuide\system\voice\TsfrCallFrom.wav, C:\Program Files\VoiceGuide\system\voice\TsfrAskAccept.wav, 9054799301, , 1
013309.76 6 PlaySoundStartNumbers ok
013325.04 6 wb(71042411)
013325.09 6 Play End line[6] (id=710424)
013325.16 6 LsXferPlayAnn EV_PLAY_FINISHED
013325.21 6 tapic lineGenerateDigits(66176,!,0) => 0
013325.89 6 generate LINEGENERATETERM_DONE
013326.83 6 LsXferPlayAnn EV_TAPI_GENERATE
013326.83 6 PlayFinishCause=CallRejected
OK, I though second part of original question related to message delivery on outgoing calls...
When doing announced conference/transfer the announce message will play in a loop immediately after dialing. VG will wait about 30 seconds (by default) from the time it dialed to number for the recipient of call to accept call - and this is what we can see in the trace as well.
