SupportTeam Report post Posted 05/30/2010 08:57 PM Javier wrote: i can use the ivr software to connect to a asterix pbx like extensions with voip? Share this post Link to post
SupportTeam Report post Posted 05/30/2010 08:59 PM Yes. VoiceGuide can register itself with other SIP servers/switches (eg: asterix) which would result in those SIP servers/switches to send calls to registered numbers to VoiceGuide. You would need to use VoiceGuide v7, and run it in VoIP mode. Please see: http://www.voiceguide.com/vghelp/source/html/config_voip_register.htm Share this post Link to post
