Guest notes Report post Posted 06/03/2010 05:37 AM Sir Good day!I just only want to ask how to connect my Database into my script. My DB is MySQL, and I use EasyPHP editor application for my MySQL, I also go to the help content of VoiceGuide for connection string, but Im confuse because I dont know what I need to put to the "Server","Database","Uid",& "Pwd". see my attachment for some clarificaton.I dont have password to the MySQL and I dont know what is the server and Uid? Attachment:Test SQL DB.zip Share this post Link to post
SupportTeam Report post Posted 06/03/2010 07:15 AM Quote I dont have password to the MySQL ... so how do you connect to the database using phpMyAdmin? Have you looked at the Help file entry for the Database Query module? It has some examples of how to specify the Database and Connect String fields. Read the section that says: "The examples below use ADO.NET data providers and can only be used in VoiceGuide v7" : http://www.voiceguide.com/vghelp/source/html/moddbquery.htm You need to ensure that you have a MySQL ADO.NET data provider installed on the VocieGuide system, so that VoiceGuide is able to communicate with MySQL using ADO.NET. Share this post Link to post
Guest notes Report post Posted 06/03/2010 08:31 AM Sir see my attache file picture,as you see in window 1, I select the admin. Then the window 2 is appear Then I select the MySQL MANAGER, then in window 3 i create a database name "one" with utf8, then making table is start and also some fields,that how I create MySQL sir. Share this post Link to post
Guest notes Report post Posted 06/03/2010 08:34 AM Sorry Sir I forgot my attachment see below Attachment: window2.zip Share this post Link to post
SupportTeam Report post Posted 06/04/2010 04:16 AM To specify the connection string to the database you will need to know the username/password of a user privileged to access the databases/tables that you want to access. If you do not know these then you should speak to the database administrator or the person that installed MySQL on your system. Configuring MySQL is outside the scope of this forum. We can if you wish assist with creating the solution for you. Please contact sales@voiceguide.com if you would like to look into this. Share this post Link to post
Guest notes Report post Posted 06/05/2010 06:12 AM Okay Sir right now the username is root and the password is mysql, but still error. can you figure out what is the problem here are the log file and also script.Thanks a lot. Attached:0605_0929_vgEngine.zip Share this post Link to post
SupportTeam Report post Posted 06/05/2010 06:30 AM To connect to a particular database you need to have that databases ADO.NET Data Provider installed. To connect to MySQL database you need to have MySQL's ADO.NET Data Provider installed. From traces we can see that you have not yet installed the MySQL's ADO.NET Data Provider on your system. Once if is installed, you then need to specify it as the Data Provider. Please see the MySQL example for v7 in this Help file page: http://www.voiceguide.com/vghelp/source/html/moddbquery.htm 100703.093 6 3 2 db strDatabaseName=[system.Data.SqlClient] strDbConnectString=[Data Source=127.0.0.1;Database=one;User ID=root;Password=mysql;] sAdoNetFactoriesAvailable=[|System.Data.Odbc|System.Data.OleDb|System.Data.OracleClient|System.Data.SqlClient|System.Data.SqlServerCe.3.5|VistaDB.NET20|] Share this post Link to post
Guest notes Report post Posted 06/05/2010 11:59 AM Sir I need to download ADO.NET,this is available form the internet Share this post Link to post
SupportTeam Report post Posted 06/06/2010 12:28 PM Try typing this into Google: MySQL ADO.NET Data Provider Share this post Link to post
