Integration With Our Software / Application
Hello sir,
Brief about Problem.
We have a web site developed in dot net, we have requirement that we want to use IVR solution in our web site. ie. if caller call to our IVR system then on the basis of that keys pressed by caller we want to take some actions or insert data in database . does it possible using voice guide.
Regards
ashok salve.
Pune'
VoiceGuide can read data from and insert data into the data base. It's very straightforward to achieve it.
You would use the Database Query module to achieve this. Please see: http://www.voiceguide.com/vghelp/source/html/moddbquery.htm
Some of the demo scripts installed when you install VoiceGuide show how data entered by caller is then inserted into the database as well.
Please let us know if you have any questions.
