Guest fsoudbakhsh Report post Posted 06/26/2010 08:03 AM Hello, bellow log section demonstrate the inquiry from database that end to error. no other inquiry has this erro but this raw. I don't see any problem with this data in my database. the Deposit raw has data and can't see any problem with it. but I don't know why I get "[LookForDeposit] movelast err :" Thanks 153634.75 5 state [LookForDeposit] DB Query 153634.75 5 db Jet mode used (To use ODBC mode specify ODBC Connect string) 153634.77 5 db About to execute a Retrieve type operation [select Deposit from IndividualAccount where CNUM = "2940836666"] 153634.77 5 db [LookForDeposit] movelast err : 153634.77 5 next module is [worngPin] (idx=26) 153634.77 5 Play Module start Share this post Link to post
SupportTeam Report post Posted 06/26/2010 09:39 AM It looks like you are using either v5 or v6 of VoiceGuide. Trace shows that the database query returned no rows. Share this post Link to post
