Guest Guest_Alex Report post Posted 10/09/2003 06:10 AM Regarding doing Conference call application, it must able to tracking the time was spent and stored in DB. (Start time=when a call success connect to external line, End time=When end call from the external line) Q1. So, isn't the hardware and software as below were able to do it? Hardware requestment intel analog D/41JCT-LS - port voice, softfax, analog interface, half-size PCI, Caller ID, CTBus.-S$1100 Software requestment 1. Voice Guide 4 line Enterprise version(1line-$248, 4 line 449). 2. VG Dialer add-on option(1 line-$129, 4 line 449), Q2. Isn't anyone tested this intel analog D/41JCT-LS card in Singapore? Q3. Need the the PABX system? Q4. Has any simply code sample i'm can refer for it? Q5. If the conference call is oversea, isn't the VG Dialer able to do it? Q6. For VOIP, isn't only can be done only with involve PABX system has VOIP feature? Welcome of any suggest/idea/help. Have a nice day. Share this post Link to post
SupportTeam Report post Posted 10/09/2003 07:02 AM Q1. So, isn't the hardware and software as below were able to do it? D/41JCT-LS is OK for this application. 2. Isn't anyone tested this intel analog D/41JCT-LS card in Singapore? The D/41JCT-LS has been certified for use pretty much all over the world, you can confirm this with your local Intel/Dialogic distributor, in your case: Attrix Technology Pte Ltd 390 Havelock Road #04-02 , King's Centre Singapore 169662 Tel: +65 6738 1661 Fax: +65 6738 2662 Email: sales@attrix.com Contact Person: Betty Yap Q3. Need the the PABX system? No. Q4. Has any simply code sample i'm can refer for it? No sample apps showing such an application are available at this stage - you will have to write it yourself (it does not sound that difficult) Q5. If the conference call is oversea, isn't the VG Dialer able to do it? Any number can be dialed. Q6. For VOIP, isn't only can be done only with involve PABX system has VOIP feature? VoiceGuide does not support VoIP at this stage - if you want calls to go over VoIP you will need a PBX which can do this and locate VoiceGuide behind that PBX. Share this post Link to post
