Guest clesson Report post Posted 02/17/2003 02:30 AM I have several D140B boards and one D/121A board. Can these be used with your software? I plan on using the D/121A for here, but selling the others if they can be used. TIA for any comments or feedback :-) clesson@duke.net Share this post Link to post
SupportTeam Report post Posted 02/17/2003 03:31 AM Neither of these cards are supported... The cards that are supported are listed on: http://www.katalinatech.com/suppRecomHardware.htm Above list is based on the Dialogic's "taprefnt.chm" help file, the relevat page I quote below: Supported Hardware The Dialogic Generation 2 TSP supports the following Dialogic boards: D/4PCI D/21D and D/41D D/21H and D/41H DIALOG/4 ProLine/2V D/41E and D/41ESC D/41EPCI D/41JCT D/42-NE2 (ISA and PCI) D/120JCT-LS D/160SC, D/160SC-LS, and D/160SC-HS D/240SC, D/240SC-T1, D/240PCI-T1, and D/240JCT-T1 D/300SC-E1, D/300JCT-E1-75, D/300PCI-E1, and D/300JCT-E1-120 D/320SC VFX/40ESCplus Share this post Link to post
Guest Clesson Report post Posted 02/17/2003 04:10 PM Thanks... I know what is listed as "Supported", but my question was NOT whether you support old boards, but whether it would work with them. Do you know if anyone has tried? Share this post Link to post
SupportTeam Report post Posted 02/17/2003 09:28 PM I can't recall any user feedback regarding these cards - If you want to try using them and post your results here I think we'd all appreciate it, Share this post Link to post
Guest Clesson Report post Posted 02/18/2003 12:04 AM I'll give it a try and let you know if it works. This may be a while as the first priority is to find a system htat works with on or the other board(s). Lacking that I'll be 'trying' packages to see what works. Yours would be the 1st. Share this post Link to post
