Using .vgp
I'm using .vgp files for protected mode. (My vgEngine version : 7.1.3868.40484)
The only thing that I do is complete the path section with the .vgp extension of file name.
But, I see in the .ini file some entries that referral to this theme.
;VmSystemUsed settings allowed:
;Scripted : VoiceGuide will use the scritps (.VGS) in \system\vm\ directory.
;Protected : VoiceGuide will use the protected scritps (.VGP) in \system\vm\ directory.
;The protected scripts are copies of the ".VGS" Voicemail files but cannot be changed/substituted.
;If a setting of "Scripted" is specified and the software is registered in "Standard" or
;"Professional" mode then the software will act as if "Protected" is specified.
VmSystemUsed=Scripted
So, my system works correctly in the protected mode with this .ini file configuration.
Wich is the difference between using VmSystemUsed=Scripted or VmSystemUsed=Protected ???
Thanks, Diego Bellini
This setting refers to the voicemail system's scripts only. It doe not affect any other scripts.
