Mimimise Record Length
Hi there,
I am moving/ftp my recorded sound files to a Website.
Are there any tricks or methods I can absolutley minimise file size of the recorded message?
I recognise I should detect hang up as soon as possible - (which Doesnt currently work that well)....
any others?
thank you
Would you suggest I do something like use the VB script module to run a conversion program on the .wav to turn it into an MP3/4?
Probably do the conversion from the same script that is moving the files to your web server. Or you can modify VoiceGuide's \System\vm\vm_ftp.vbs script if you have just selected to FTP the voicemail messages.
