scotthyde1 Report post Posted 09/09/2010 01:35 AM Hi there, I am moving/ftp my recorded sound files to a Website. Are there any tricks or methods I can absolutley minimise file size of the recorded message? I recognise I should detect hang up as soon as possible - (which Doesnt currently work that well).... any others? thank you Share this post Link to post
SupportTeam Report post Posted 09/09/2010 05:25 AM Quote Are there any tricks or methods I can absolutley minimise file size of the recorded message? You could try converting them to .mp4 etc. before uploading. Quote I recognise I should detect hang up as soon as possible - (which Doesnt currently work that well).... Have you looked at: http://www.voiceguide.com/vghelp/source/html/disconnectiondetect.htm Share this post Link to post
scotthyde1 Report post Posted 09/09/2010 05:48 AM Would you suggest I do something like use the VB script module to run a conversion program on the .wav to turn it into an MP3/4? Share this post Link to post
SupportTeam Report post Posted 09/09/2010 10:50 AM Probably do the conversion from the same script that is moving the files to your web server. Or you can modify VoiceGuide's \System\vm\vm_ftp.vbs script if you have just selected to FTP the voicemail messages. Share this post Link to post
