mikeraut Report post Posted 09/10/2010 08:58 AM Please assist, the line anwsers, I leave a message but the disconnect tone does not seem be recognised - so the line never hangs up until I do a shutdown 0910_1050_vgEngine.zip Share this post Link to post
SupportTeam Report post Posted 09/10/2010 09:21 AM Please see: http://www.voiceguide.com/vghelp/source/html/disconnectiondetect.htm If you have problems with the above please post again and advise at which stage you encountered a problem. Share this post Link to post
mikeraut Report post Posted 09/10/2010 01:00 PM That is the reason I have attached a logfile - the line does not release, even though vg is detecting the disconnect tone Share this post Link to post
SupportTeam Report post Posted 09/10/2010 09:26 PM Trace shows: 105111.812 6 3 2 state [VmLmRec] Recording C:\Program Files\VoiceGuide\data\VmSave\100_0910105111_1_3_100_.wav 105126.390 18 3 2 ev CallState LINECALLSTATE_DISCONNECTED-DISCONNECT_USER_1, crn=10000001, iEvent=2 ,16384,0,64,,,]. vgEngine v7.1.3902.41834 (2010-09-07 22:14:27.96) 105126.406 6 3 2 qScr run evCallState sCode=[LINECALLSTATE_DISCONNECTED-DISCONNECT_USER_1] iActionID=0, crn=10000001[16384|0|64|0|0][|||||] 105126.406 6 3 2 LineEvCallState eLineStateThisEvent=Disconnected 105126.406 6 3 2 LineEvCallState ScriptState=LS_REC_RECORDING 105126.406 6 3 2 ls set Disconnected (scriptstate=LS_REC_RECORDING) 105126.406 6 3 2 yLineStateAppPov: Disconnected crn=10000001,ev=2,LINECALLSTATE_DISCONNECTED-DISCONNECT_USER_1,0, sParam1= 105126.406 6 3 2 LineEvCallState LINECALLSTATE_DISCONNECTED begin 105126.406 6 3 2 in LINECALLSTATE_DISCONNECTED iState=LS_REC_RECORDING 105126.406 6 3 2 qScr add evScriptEvent 9250 DISCONNECTED 105126.406 6 3 2 HangupCall, source=LINECALLSTATE_DISCONNECTED, WorkModeScript=Running_Normal, yLineStateAppPov=[Disconnected], lPlayId=0, lRecId=28484 105126.406 6 3 2 HangupCall ignored due to current yLineStateAppPov=Disconnected 105126.453 18 3 2 ev Dialogic 130,TDX_RECORD, crn=10000001, 0,0,0,TM_USRSTOP,, 105126.453 6 3 2 qScr run evScriptEvent sCode=[TDX_RECORD] iActionID=0, crn=10000001[0|0|0|0|0][TM_USRSTOP|||||] 105126.453 6 3 2 qScr run evScriptEvent sCode=[EV_REC_FINISHED] iActionID=0, crn=0[0|0|0|0|0][|||||] 105126.453 6 3 2 WARN rec complete event without rec reason being recieved first. Assume silence as the cause 105126.453 6 3 2 path {silence} found (at offset 329) 105126.453 6 3 2 FindNextVgmTitleInPathList: next module title is=[VmLmHangup] 105126.453 6 3 2 t timer clear (force=False) 105126.453 6 3 2 RunModule start Hangup the Call, [VmLmHangup], iModuleIdx=15, previous: vgm=8, vgs=2 105126.453 6 3 2 HangupCall, source=Hangup Module, WorkModeScript=Running_Normal, yLineStateAppPov=[Disconnected], lPlayId=0, lRecId=0 105126.453 6 3 2 HangupCall ignored due to current yLineStateAppPov=Disconnected Will have a look at this and advise. Should have an answer within 24 hours. Share this post Link to post
SupportTeam Report post Posted 09/11/2010 11:30 AM Please update system to this version of VoiceGuide and post traces as before if you still encounter problems:[old link removed] Share this post Link to post
mikeraut Report post Posted 09/12/2010 01:59 AM Thank you, the line now hangs up after the caller has left a message. Share this post Link to post
