Script Properties
I am trying to call a script to send an SMS notification after a voice message has been left. This should happen once the call has hung up. Please check the attached log file as I can't seem to get it to run the "SMS Notification.vgs".
0914_1149_vgEngine.zip
The SMS Notification.vgs is set to be the "run on hangup" script for the ManicaTransferMenu.vgs script.
Trace shows that when the call was answered the script was ManicaTransferMenu.vgs was ran, but then the ManicaTransferMenu.vgs script jumped to the voicemail script VmLm.vgs
VmLm.vgs has its own "run on hangup" script set (vmLmHangup.vgs)
The "run on hangup" script that is ran will depend on which script is running at the time the hangup occurs.
You will need to edit the vmLmHangup.vgs and add to it the ManicaTransferMenu.vgs contents.
