Guest u4910 Report post Posted 09/29/2010 03:03 AM If I put in multiple Dialogic analog cards in one system, do they need to be connected together via a cable? For the licence, what license file to I add the licenses into? Share this post Link to post
SupportTeam Report post Posted 09/29/2010 07:17 AM If a least one of the cards has the CT-Bus connector on it then you need to have all the cards connected via CT-Bus cable. Only if all the cards in system are D/4PCIUF type cards then you do not need any cable. Share this post Link to post
Guest u4910 Report post Posted 09/30/2010 01:50 AM That's exactly what I have. Thanks. There is no limit on the number of cards in a system other than the number of slots that it can hold, right? Share this post Link to post
SupportTeam Report post Posted 09/30/2010 08:24 AM There is no limit on the number of cards in a system other than the number of slots that it can hold, right? Practically speaking, no. The max number of D/4PCIUF cards in one system is around 16 mark. Some sites use bus extender boxes to achieve this. Share this post Link to post
