metra Report post Posted 09/29/2010 05:17 PM We are using VG 7 over an E1 Dialogic Board (D/300JCT) and we need to share the 30 lines between different applications and also to dedicate specific numbers to each application Is it possible to share a E1 dialogic board between different application ? By example - dedicate 10 lines and also 10 specific phone numbers to VG - reserve 10 lines for a fax application - use the 10 last lines for other purpose Share this post Link to post
SupportTeam Report post Posted 09/29/2010 09:28 PM Sharing the E1 ISDN card will probably not work. You can try it and see but would not expect this to work. BTW. VoiceGuide supports fax and has support for intelligent fax routing. Share this post Link to post
