amiller Report post Posted 09/29/2010 11:37 PM I havent used my dialer or voiceguide software in awhile. The computer i had it on was outdated and the motherboard was not working. I loaded everything onto a new machine and it will not work. Is there any solution to get this working on my new machine( i saw where it will only work on the machine it was originally loaded on). Share this post Link to post
SupportTeam Report post Posted 09/30/2010 08:27 AM What is the actual problems that you are encountering? Can you post VoiceGuide traces capturing system startup? (please .ZIP up traces before posting) Share this post Link to post
amiller Report post Posted 10/01/2010 03:29 PM in my license manager i am getting this error when i try to activate my license: no boards found access to the path c:/programfiles/voiceguide/userinfo.cic is denied When i moved this over to my new machine i copied the software on to a flash drive and loaded it onto the new machine. Share this post Link to post
amiller Report post Posted 10/01/2010 03:58 PM when i transvered the board and software to the new machine, i put the files on a flash drive and transferred them over. when i open my licese manager i get the following response: licMgr Load_Layer_kttel_dynamic assembly.load c:\program files\voiceguide\ktdialogicsr60vista.dll system.IO.filenotfoundexception: the specified module could not be found. (exeption from HRESULT:0x8007007E) at system.reflection.assembly._nload(assemblyName filename, string codebase, evidence assemblysecurity, assembly locationhint, stackcrawlmark&stackmark, boolean throwonfilenotfound,boolean forintrospection)at system.reflection.assemblysecurity,stackcrawlmark& stackmark, boolean forintrospection) at system.reflection.assembly.internalloadfrom(string assemblyfile, evidence securityevidence, byte[] hashvalue, assemblyhashalgorithm hashalgorithm, boolean forintrospection, stackcrawlmark& stack mark) at system.reflection.assembly.loadfrom(string assemblyfile) at Share this post Link to post
SupportTeam Report post Posted 10/01/2010 09:48 PM What version of Windows are you using? Are you logged in as Administrator and running the applications as Administrator? It may be better for you to run the install rather then just copying files across. The Dialogic drivers should be installed and confirmed as working first, before installing VoiceGuide. Share this post Link to post
amiller Report post Posted 10/01/2010 10:01 PM I am running vista with service pack 1. I dont see an option to install. Share this post Link to post
SupportTeam Report post Posted 10/01/2010 10:05 PM Download VoiceGuide v7 install from our WWW Downloads page and run that install. You must install the Dialogic drivers first. Best to confirm Dialogic card operation before installing VG. There are sample applications installed with Dialogic drivers that you can use to test the card before installing VoiceGuide. Share this post Link to post
amiller Report post Posted 11/04/2010 02:30 AM I am unable to find that software for download on your site. I have my board working properly now but need to have a freash download of the software. Share this post Link to post
SupportTeam Report post Posted 11/04/2010 04:43 AM Links to all software necessary are on our Downloads page? Which software in particular do you need to download? Share this post Link to post
amiller Report post Posted 11/04/2010 06:59 AM I have a valid license for the 4 line Enterprise+Dialer license, i will be happy to provide you with my unique id. Share this post Link to post
SupportTeam Report post Posted 11/04/2010 07:19 AM For all license related enquiries please contact sales@voiceguide.com It does however sound like you will first need to properly install the software on your new system. Share this post Link to post
