Inbound Fax
Hi
just reading re V 7 and it would seem Faxing is now better supported - I remember asking a few years ago about this and don't think it was then.
Can a Fax and call both come in on SAME line - and if so how and where is it determined so you can trigger different paths?
or do you need explicitly different inbound lines - and then have a record module - the one associated to the Fax line - always record to a pdf for example...and use from there..
thanks
Forgive me if this is a dumb question - But I dont see the "On fax" in any of the ON choices in any of the modules
The "on {fax}" path needs to be types in by hand.
on {fax} goto [somemodulename]
