Incoming Voip Calls Not Working
I have installed Dialogic HMP 3.0 to work with VG.
When i use the Demo of Dialogic it works fine.
When i try to use VG, i am getting from SJPhone 488 Not acceptable here.
Pleas find attached the traces from VG.
Thanks,
Haim
1007_0905_vgEngine.zip
Can you post a WireShark log capturing the incoming SIP packets? Please post that along with the VoiceGuide traces.
It looks like the call from SJ Phone is trying to use a codec other then G.711, but we need to see WireShark trace to confirm.
WireShark can be obtained from www.wireshark.org
It is used to trace packets received/sent over the network.
You can limit the visible trace to SIP packets by typing SIP in the 'Filter' text box.
