bfrank Report post Posted 10/07/2010 07:45 PM Hello guys. It seems that VG is returning busy although there are plenty of open channels. The number of busy responses increase proportional to incoming call volume. The problem gets progressively worse as time goes on. In the beginning of September (last restart) we were rejecting 0 calls. This week we rejected 15-20% of incoming calls. I zipped up part of the ktTel log for 10/06. On this day we rejected at least 590 calls. I also zipped a vgEngine log for 11:00 to 11:44 AM. During this time frame we rejected at least 8 calls. I can't find the problem calls in the logs, but I can see in my CDRs that we rejected calls at the following times: 2010-10-06 11:06:11.000 2010-10-06 11:06:20.000 2010-10-06 11:08:08.000 2010-10-06 11:08:25.000 2010-10-06 11:08:25.000 2010-10-06 11:08:33.000 2010-10-06 11:10:29.000 2010-10-06 11:38:38.000 UPDATE: By looking at the logs it appears that I'm only accepting calls on 8 lines (out of 24). I now went to the VG Viewer application and "hung up" the stuck ports. This seems to solve the problem. The new version (7.0) was supposed to solve the stuck port issue (see this thread and this one) but actually solved nothing? It just hid it from view, which of course made things worse. logs.zip Share this post Link to post
SupportTeam Report post Posted 10/07/2010 10:48 PM From looking at logs we can see that what is happening here is that either: A: Call are never arriving at system or B: HMP is not reporting the incoming calls to VoiceGuide Had a look at the ktTel log to see if HMP reported to VoiceGuide that these calls arrived at system: 2010-10-06 11:06:11.000 2010-10-06 11:06:20.000 VoiceGuide logs show that these two calls were not reported to VoiceGuide by HMP. Here are the calls around that time that were reported by HMP to VoiceGuide: 110547.803 5380 64 ev GCEV_DETECTED crn=8000015 (setting hli->crn for line 64) 110547.803 5380 64 ev GCEV_OFFERED crn=8000015 (ktTel_HMP30 v7.1.0, Jun 16 2010 14:54:22) (setting hli->crn for line 64) 110547.850 5380 64 ev GCEV_ANSWERED crn=8000015 (ktTel_HMP30 v7.1.0, Jun 16 2010 14:54:22) 110550.490 5380 19 ev GCEV_DETECTED crn=8000006 (setting hli->crn for line 19) 110550.490 5380 19 ev GCEV_OFFERED crn=8000006 (ktTel_HMP30 v7.1.0, Jun 16 2010 14:54:22) (setting hli->crn for line 19) 110550.568 5380 19 ev GCEV_ANSWERED crn=8000006 (ktTel_HMP30 v7.1.0, Jun 16 2010 14:54:22) 110558.990 5380 16 ev GCEV_DETECTED crn=8000005 (setting hli->crn for line 16) 110558.990 5380 16 ev GCEV_OFFERED crn=8000005 (ktTel_HMP30 v7.1.0, Jun 16 2010 14:54:22) (setting hli->crn for line 16) 110559.068 5380 16 ev GCEV_ANSWERED crn=8000005 (ktTel_HMP30 v7.1.0, Jun 16 2010 14:54:22) 110658.146 5380 64 ev GCEV_DETECTED crn=8000015 (setting hli->crn for line 64) 110658.146 5380 64 ev GCEV_OFFERED crn=8000015 (ktTel_HMP30 v7.1.0, Jun 16 2010 14:54:22) (setting hli->crn for line 64) 110658.209 5380 64 ev GCEV_ANSWERED crn=8000015 (ktTel_HMP30 v7.1.0, Jun 16 2010 14:54:22) 110711.600 5380 16 ev GCEV_DETECTED crn=8000005 (setting hli->crn for line 16) 110711.600 5380 16 ev GCEV_OFFERED crn=8000005 (ktTel_HMP30 v7.1.0, Jun 16 2010 14:54:22) (setting hli->crn for line 16) 110711.646 5380 16 ev GCEV_ANSWERED crn=8000005 (ktTel_HMP30 v7.1.0, Jun 16 2010 14:54:22) all the calls that did arrive from VoiceGuide's point of view were answered and then handles with no issues. Given that you say: By looking at the logs it appears that I'm only accepting calls on 8 lines (out of 24). I now went to the VG Viewer application and "hung up" the stuck ports. This seems to solve the problem. How did you determine that the ports were 'stuck'? What was the Line Viewer's status for those stuck ports showing? Do you perhaps have a screenshot? The previous 'stuck' lines problem were caused by HMP/VoiceGuide not receiving SIP packets from other systems confirming calls have been disconnected after the RFC3515 Refer transfer was made. (see: http://voiceguide.com/forums/index.php?showtopic=6469 ) Perhaps we are now seeing another similar problem where SIP signaling packets not arriving. Share this post Link to post
SupportTeam Report post Posted 10/08/2010 07:01 AM Can you .ZIP up and post the VoiceGuide traces which capture when you manually pressed the 'hangup call' button for the 'stuck' ports. This will let us see what the system did at the time the 'hangup call' button was pressed and from there we may see what state the channel was in. Ultimately it would be best to get the VoiceGuide ktTel traces capturing the last call handled by each of the 'stuck' channels. This way we would be able to see what unusual activity happened on the channel during that last call that may have led to the port being 'stuck'. Since the last VoiceGuide service restart was over a month ago then there would a few files to search through, but the the last trace file that contains activity for a particular channel can be identified by grepping the ktTel traces for the channel id and finding which trace last had activity on that channel. Share this post Link to post
bfrank Report post Posted 10/08/2010 01:21 PM I went back to see when a particular channel stopped working. According to the logs, line ID 37 stopped accepting calls on 9/2/2010 somewhere around 15:12:00. I attached the logs for that time frame to this post. Please see if you can find anything that may have caused the issue. RE: How did you determine that the ports were 'stuck'? What was the Line Viewer's status for those stuck ports showing? By noticing how channels dropped out of the logs throughout September, one by one, until there were eight left. I then observed how the Status Viewer hunts and assigns lines, and saw that only 8 were being utilized. Then I noticed (silly me for overlooking this before) that the column showing Last Call End Time showed end times way back in the past for all the "stuck" ports. That's when I hung them up manually and they went back into rotation. logs-for-9-2-10.zip Share this post Link to post
SupportTeam Report post Posted 10/08/2010 07:25 PM Trace shows that last action attempted on channel with LineId of 37 (port 12) before problems arose was an RFC3515 transfer. The HMP drivers reported that the RFC3515 transfer failed. Can you please post these traces (.ZIPed): - vgEngine trace file which is next after 0902_1433_vgEngine.txt (probably called 0902_1515_vgEngine.txt) - ktTel and vgEngine which capture the time when you manually issued the 'Hangup' command on these lines. - Dialogic RTF trace which covers Sept 2nd (see: C:\Program Files\Dialogic\log) Relevant trace extracts below. grep " 37 12 " *_vgEngine.txt > id37vge.txt 151131.875 6 37 12 state [DoTransfer] Blind Hookflash Transfer to 213477362223@201.161.45.52 151131.875 6 37 12 xfer RFC3515 transfer to 213477362223@201.161.45.52 151131.875 6 37 12 timer set completed lTimeLeft250msUnits=120, iTimeoutCode=9001 151131.875 19 37 12 ev Dialogic 2049,GCEV_TASKFAIL, crn=800000c, 2049,0,0,,, 151131.875 6 37 12 scriptevent GCEV_TASKFAIL param1:, param2:, param3: 151131.875 6 37 12 LsXfer_1_Start : 2049(EV_UNKNOWN_2049),GCEV_TASKFAIL,2049,0,0,,, 151131.875 6 37 12 path {GCEV_TASKFAIL} not found 151131.890 19 37 12 ev Dialogic 2054,GCEV_RESETLINEDEV, crn=0, 2054,0,0,,, 151131.890 19 37 12 LineState_Reinit_CleanLineState : begin 151131.890 19 37 12 ls set Null_InGuardTimeAfterEndOfCall (scriptstate=LS_XFER_1_START) 151131.890 19 37 12 ScriptWorkingMode set Idle_WaitingForNextCall, (called from LineState_Reinit_CleanLineState) 151131.890 19 37 12 state Waiting for a call... 151131.890 6 37 12 scriptevent GCEV_RESETLINEDEV param1:, param2:, param3: 151131.890 6 37 12 LsXfer_1_Start : 2054(EV_UNKNOWN_2054),GCEV_RESETLINEDEV,2054,0,0,,, 151131.890 6 37 12 path {GCEV_RESETLINEDEV} not found 151201.875 6 37 12 scriptevent EV_TIMEOUT_HANGUP param1:, param2:, param3: 151201.875 6 37 12 LsXfer_1_Start : 9001(EV_TIMEOUT_HANGUP),EV_TIMEOUT_HANGUP,0,0,0,,, 151201.875 6 37 12 path {EV_TIMEOUT_HANGUP} not found 151201.875 6 37 12 HangupCall, source=LsDefaultHandlers:EV_TIMEOUT_HANGUP, WorkModeScript=Idle_WaitingForNextCall, yLineStateAppPov=[Null_InGuardTimeAfterEndOfCall], lPlayId=0, lRecId=0 151201.875 6 37 12 moduleTitle=[DoTransfer] 151201.875 6 37 12 ScriptWorkingMode set Stopping, (called from HangupCall) 151201.875 6 37 12 ls set Disconnect_Pending (scriptstate=LS_ENDINGCALL) 151201.875 6 37 12 state Hanging up... [LsDefaultHandlers:EV_TIMEOUT_HANGUP] 151201.875 6 37 12 rv add [Hangup Source]{LsDefaultHandlers:EV_TIMEOUT_HANGUP} 151201.875 6 37 12 GoOnHoook_IssueDropCall start (hCall_crn=0) 151201.875 6 37 12 timer set completed lTimeLeft250msUnits=40, iTimeoutCode=9101 151201.875 6 37 12 GoOnHoook_IssueDropCall end 151201.875 19 37 12 ev Dialogic 2049,GCEV_TASKFAIL, crn=800000c, 2049,0,0,,, 151201.875 6 37 12 scriptevent GCEV_TASKFAIL param1:, param2:, param3: 151201.875 6 37 12 LsEndingCall GCEV_TASKFAIL 2049 151201.875 19 37 12 ev Dialogic 2054,GCEV_RESETLINEDEV, crn=0, 2054,0,0,,, 151201.875 19 37 12 LineState_Reinit_CleanLineState : begin 151201.875 19 37 12 ls set Null_InGuardTimeAfterEndOfCall (scriptstate=LS_ENDINGCALL) 151201.875 19 37 12 ScriptWorkingMode set Idle_WaitingForNextCall, (called from LineState_Reinit_CleanLineState) 151201.875 19 37 12 state Waiting for a call... 151201.875 6 37 12 scriptevent GCEV_RESETLINEDEV param1:, param2:, param3: 151201.875 6 37 12 LsEndingCall GCEV_RESETLINEDEV 2054 151201.875 19 37 12 ev Dialogic 2054,GCEV_RESETLINEDEV, crn=0, 2054,0,0,,, 151201.875 19 37 12 LineState_Reinit_CleanLineState : begin 151201.875 19 37 12 ls set Null_InGuardTimeAfterEndOfCall (scriptstate=LS_ENDINGCALL) 151201.875 19 37 12 ScriptWorkingMode set Idle_WaitingForNextCall, (called from LineState_Reinit_CleanLineState) 151201.875 19 37 12 state Waiting for a call... 151201.875 6 37 12 scriptevent GCEV_RESETLINEDEV param1:, param2:, param3: 151201.875 6 37 12 LsEndingCall GCEV_RESETLINEDEV 2054 151211.875 6 37 12 scriptevent EV_TIMEOUT_WAITFORIDLEAFTERDropCall param1:, param2:, param3: 151211.875 6 37 12 state Hanging up call...(2) 151211.875 6 37 12 ls set Null (scriptstate=LS_ENDINGCALL) 151211.875 6 37 12 no script running on this line. AfterHangup script will not be ran. 151211.875 6 37 12 AllScritpsCompleted_Cleanup start 151211.875 6 37 12 ScriptWorkingMode set Idle_WaitingForNextCall, (called from AllScritpsCompleted_Cleanup) 151211.875 6 37 12 WriteToLogFiles_CurrScriptOnly begin 151211.875 6 37 12 WriteToLogFiles_CurrScriptOnly : LineState.iVgsIdx<=0 151211.875 6 37 12 RvSaveToLogFiles_CurrAndStack iScriptCallStack_LastUsed_Idx=0 151211.875 6 37 12 LineState_Reinit_CleanLineState : begin 151211.875 6 37 12 ls set Null_InGuardTimeAfterEndOfCall (scriptstate=LS_ENDINGCALL) 151211.875 6 37 12 ls set ignore new linestate set as current linestate is Null 151211.875 6 37 12 ScriptWorkingMode set Idle_WaitingForNextCall, (called from LineState_Reinit_CleanLineState) 151211.875 6 37 12 timer set completed lTimeLeft250msUnits=12, iTimeoutCode=9013 151211.875 6 37 12 state Waiting for a call... 151211.875 6 37 12 ScriptWorkingMode set Idle_WaitingForNextCall, (called from LineState_Reinit_AndReleaseCall) 151211.875 19 37 12 ev Dialogic 2054,GCEV_RESETLINEDEV, crn=0, 2054,0,0,,, 151211.875 19 37 12 LineState_Reinit_CleanLineState : begin 151211.875 19 37 12 ls set Null_InGuardTimeAfterEndOfCall (scriptstate=LS_NULL_AWAITINGCALLS) 151211.875 19 37 12 ls set ignore new linestate set as current linestate is Null 151211.875 19 37 12 ScriptWorkingMode set Idle_WaitingForNextCall, (called from LineState_Reinit_CleanLineState) 151211.875 19 37 12 state Waiting for a call... 151211.875 6 37 12 scriptevent GCEV_RESETLINEDEV param1:, param2:, param3: 151211.875 6 37 12 LsAwaitingCalls GCEV_RESETLINEDEV 151214.875 6 37 12 scriptevent EV_TIMEOUT_AFTERIDLE_ALLOWOUT param1:, param2:, param3: 151214.875 6 37 12 ls set Null (scriptstate=LS_NULL_AWAITINGCALLS) grep " 37 " *_ktTel.txt > id37kt.txt 151131.875 1640 37 fn TransferBlind(37,0,213477362223@201.161.45.52,77918140) 151131.875 1640 37 TelDriver_TransferBlind start 151131.875 1640 37 TelDriver_TransferBlind no SIP: or TA: prefix specified. Adding SIP: prefix to the transfer destination. 151131.875 1640 37 CallTransfer_Invoke start 151131.875 1640 37 gc_InvokeXfer SIP:213477362223@201.161.45.52 151131.875 1640 37 gc_InvokeXfer SIP:213477362223@201.161.45.52 ok 151131.875 5380 37 CtEventProcess idx=2211 : evttype=2049(2049), crn=800000c, data=091C2218(08901C60), len=8(8) q: 0/12 151131.875 5380 37 ev GCEV_TASKFAIL crn=800000c 151131.875 5380 37 gc_ErrorInfo gcValue=10(0xa), gcMsg=[Function is not supported], ccLibId=0, ccLibName=[GLOBALCALL], ccValue=0xa, ccMsg=[Function is not supported], additionalInfo=[] 151131.875 5380 37 t_info: gcValue=137(0x89) gcMsg=[CCLIB specific] ccLibId=8 ccLibName=[GC_H3R_LIB] ccValue=[0x6] ccMsg=[iPERR_INTERNAL - see rtf log] additionalinfo=[] 151131.875 5380 37 r Dialogic GCEV_TASKFAIL 2049 (2049 0 0 ) 151131.875 5380 37 calling gc_ResetLineDev. taskfail_crn=800000c, hli->crn=800000c 151131.890 5380 37 CtEventProcess idx=2212 : evttype=2054(2054), crn=0, data=091C2248(08901C60), len=8(8) q: 0/12 151131.890 5380 37 ev GCEV_RESETLINEDEV - gc_ResetLineDev function completed 151131.890 5380 37 SetChanStateInServiceAndWaitCall call from GCEV_RESETLINEDEV 151131.890 5380 37 SetChanStateInServiceAndWaitCall: gc_setchanstate not called in this version. 151131.890 5380 37 gc_WaitCall call in SetChanStateInServiceAndWaitCall 151131.890 5380 37 gc_WaitCall ok 151131.890 5380 37 r Dialogic GCEV_RESETLINEDEV 2054 (2054 0 0 ) 151201.875 1640 37 fn DropCall(sLineId=37, sXMLOptions=[], crn=0) 151201.875 1640 37 TelDriver_DropCall(sXMLOptions=[], crn_in=0) 151201.875 1640 37 clearing sDTMFsReceivedBeforeCallAnswer in TelDriver_DropCall 151201.875 1640 37 gc_DropCall iCrnToDrop=800000c cause=16:GC_NORMAL_CLEARING (nocausetag) 151201.875 1640 37 ERROR gc_DropCall iCrnToDrop=800000c 151201.875 1640 37 gc_ErrorInfo gcValue=137(0x89), gcMsg=[CCLIB specific], ccLibId=8, ccLibName=[GC_H3R_LIB], ccValue=0x6, ccMsg=[iPERR_INTERNAL - see rtf log], additionalInfo=[] 151201.875 1640 37 gc_ResetLineDev ok (called from gc_DropCall_ERROR) 151201.875 5380 37 CtEventProcess idx=2245 : evttype=2049(2049), crn=800000c, data=091C2878(08901C60), len=8(8) q: 1/12 151201.875 5380 37 ev GCEV_TASKFAIL crn=800000c 151201.875 5380 37 gc_ErrorInfo gcValue=10(0xa), gcMsg=[Function is not supported], ccLibId=0, ccLibName=[GLOBALCALL], ccValue=0xa, ccMsg=[Function is not supported], additionalInfo=[] 151201.875 5380 37 t_info: gcValue=1014(0x3f6) gcMsg=[unknown error or result] ccLibId=8 ccLibName=[GC_H3R_LIB] ccValue=[0x42] ccMsg=[iPEC_InternalReasonNormal] additionalinfo=[] 151201.875 5380 37 r Dialogic GCEV_TASKFAIL 2049 (2049 0 0 ) 151201.875 5380 37 calling gc_ResetLineDev. taskfail_crn=800000c, hli->crn=800000c 151201.875 5380 37 CtEventProcess idx=2246 : evttype=2054(2054), crn=0, data=091C28A8(08901C60), len=8(8) q: 0/12 151201.875 5380 37 ev GCEV_RESETLINEDEV - gc_ResetLineDev function completed 151201.875 5380 37 SetChanStateInServiceAndWaitCall call from GCEV_RESETLINEDEV 151201.875 5380 37 SetChanStateInServiceAndWaitCall: gc_setchanstate not called in this version. 151201.875 5380 37 gc_WaitCall call in SetChanStateInServiceAndWaitCall 151201.875 5380 37 gc_WaitCall ok 151201.875 5380 37 r Dialogic GCEV_RESETLINEDEV 2054 (2054 0 0 ) 151201.875 5380 37 CtEventProcess idx=2247 : evttype=2054(2054), crn=0, data=091C28D8(08901C60), len=8(8) q: 0/12 151201.875 5380 37 ev GCEV_RESETLINEDEV - gc_ResetLineDev function completed 151201.875 5380 37 SetChanStateInServiceAndWaitCall call from GCEV_RESETLINEDEV 151201.875 5380 37 SetChanStateInServiceAndWaitCall: gc_setchanstate not called in this version. 151201.875 5380 37 gc_WaitCall call in SetChanStateInServiceAndWaitCall 151201.875 5380 37 ERROR gc_WaitCall 151201.875 5380 37 gc_ErrorInfo gcValue=65(0x41), gcMsg=[Function is not supported in this state], ccLibId=8, ccLibName=[GC_H3R_LIB], ccValue=0x9, ccMsg=[iPERR_INVALID_STATE], additionalInfo=[] 151201.875 5380 37 r Dialogic GCEV_RESETLINEDEV 2054 (2054 0 0 ) 151211.875 1640 37 fn ResetLineDev(sLineId=37, Param1=0) 151211.875 1640 37 gc_ResetLineDev ok (called from TelDriver_ResetLineDev) 151211.875 5380 37 CtEventProcess idx=2258 : evttype=2054(2054), crn=0, data=091C2AE8(08901C60), len=8(8) q: 0/12 151211.875 5380 37 ev GCEV_RESETLINEDEV - gc_ResetLineDev function completed 151211.875 5380 37 SetChanStateInServiceAndWaitCall call from GCEV_RESETLINEDEV 151211.875 5380 37 SetChanStateInServiceAndWaitCall: gc_setchanstate not called in this version. 151211.875 5380 37 gc_WaitCall call in SetChanStateInServiceAndWaitCall 151211.875 5380 37 gc_WaitCall ok 151211.875 5380 37 r Dialogic GCEV_RESETLINEDEV 2054 (2054 0 0 ) 151933.015 5380 37 CtEventProcess idx=2672 : evttype=2135(2135), crn=800000c, data=091C7888(08901C60), len=8(8) q: 1/12 151933.015 5380 37 ev GCEV_DETECTED crn=800000c (setting hli->crn for line 37) 151933.015 5380 37 CtEventProcess idx=2673 : evttype=2084(2084), crn=800000c, data=091C78B8(08901C60), len=8(8) q: 0/12 151933.015 5380 37 ev GCEV_OFFERED crn=800000c (ktTel_HMP30 v7.1.0, Jun 16 2010 14:54:22) (setting hli->crn for line 37) 151933.015 5380 37 calling CIPStateMachine_NullGcevOffered next 151933.015 5380 37 CIPStateMachine_NullGcevOffered START. sets the coders negotionation and other call paramters 151933.015 5380 37 RemoteEndsProposedCoders parm_data_buf=0xd7f97ef, parm_data_size=329 151933.015 5380 37 parm_data_ext: data_size=42, parm_ID=1, pData=0xd7f97f4, pInternal=0xd7f97ef, set_ID=12315, version=256 151933.015 5380 37 parm_data_ext: data_size=37, parm_ID=2, pData=0xd7f9823, pInternal=0xd7f981e, set_ID=12315, version=256 151933.015 5380 37 parm_data_ext: data_size=37, parm_ID=16, pData=0xd7f984d, pInternal=0xd7f9848, set_ID=12315, version=256 151933.015 5380 37 parm_data_ext: data_size=58, parm_ID=18, pData=0xd7f9877, pInternal=0xd7f9872, set_ID=12315, version=256 151933.015 5380 37 parm_data_ext: data_size=44, parm_ID=19, pData=0xd7f98b6, pInternal=0xd7f98b1, set_ID=12315, version=256 151933.015 5380 37 parm_data_ext: data_size=38, parm_ID=16, pData=0xd7f98e7, pInternal=0xd7f98e2, set_ID=12300, version=256 151933.015 5380 37 parm_data_ext: data_size=38, parm_ID=16, pData=0xd7f9912, pInternal=0xd7f990d, set_ID=12300, version=256 151933.015 5380 37 gc_util_next_parm_ex returned 'There are no more parms in the GC_PARM_BLK' 151933.015 5380 37 SetTxRxVoiceChannelCoders begin 151933.015 5380 37 codec order: 1:ULaw, 2:ALaw 151933.015 5380 37 SetTxRxVoiceChannelCoders txcoders=6, rxcoders=6 151933.015 5380 37 gc_SetUserInfo(GCTGT_GCLIB_CRN, 0x800000c, gcParmBlk=0xe3fecf0, GC_SINGLECALL) ok 151933.015 5380 37 protocol is SIP 151933.015 5380 37 gc_GetCallInfo ORIGINATION_ADDRESS_SIP=[sip:816@216.48.184.52;user=phone;tag=6998657592610064597] 151933.015 5380 37 gc_GetCallInfo DESTINATION_ADDRESS_SIP=[sip:18002978124@192.168.202.250;user=phone] 151933.015 5380 37 gc_GetCallInfo IP_CALLID=[6998657592610064597-1283455151-13842] 151933.015 5380 37 gc_GetCallInfo ORIGINATION_ADDRESS=[816@216.48.184.52] 151933.015 5380 37 gc_GetCallInfo DESTINATION_ADDRESS=[18002978124@192.168.202.250] 151933.015 5380 37 calling OnGcEvOffered_GetCallerID next 151933.015 5380 37 OnGcEvOffered_GetCallerID start (with CallerID report) 151933.015 5380 37 OnGcEvOffered_GetCallerID gc_GetCRN: crn=0x800000c (setting hli->crn for line 37) 151933.015 5380 37 gc_ErrorInfo gcValue=10(0xa), gcMsg=[Function is not supported], ccLibId=0, ccLibName=[GLOBALCALL], ccValue=0xa, ccMsg=[Function is not supported], additionalInfo=[] 151933.015 5380 37 ERROR gc_GetNetCRV in offered failed. hli->crn=0x800000c 151933.015 5380 37 could not retrieve CALLNAME 151933.015 5380 37 raising LINECALLSTATE_OFFERING next (with cid data) 151933.015 5380 37 CTelProxy::Event_CallState GCEV_OFFERED iLineCallState=2, hCall=134217740 m_pktTelProxyClient=006917D4 151933.015 5380 37 r CallState GCEV_OFFERED Share this post Link to post
bfrank Report post Posted 10/11/2010 03:17 PM I attached 3 zip files: - 0902_1515_vgEngine.zip (log following the log I attached to the last post) - 1007_1500_vgEngine.zip (log of the "hangup" actions) - 1007_ktTel.zip (ktTel log of same) The "hangup" actions occurred somewhere around 15:20. I couldn't find any Dialogic rtf trace logs for 9/2 - it looks like the logs get deleted after a day or two. Do they get archived somewhere? 0902_1515_vgEngine.zip 1007_1500_vgEngine.zip 1007_ktTel.zip Share this post Link to post
SupportTeam Report post Posted 10/12/2010 09:52 AM It looks like the fix for recovery from this situation is already in the latest version of VoiceGuide.Please update your system to this version: [old link removed]To determine cause of RFC3515 transfers failing we would need to see RTF log capturing such a failure. To capture the RTF log recommend daily grepping of VoiceGuide trace files for:GCEV_TASKFAILand if found then save all the Dialogic RTF logs and post them here along with VoiceGuide traces.It is possible that the RFC3515 transfers are failing as there are no more licenses available for HMP to make the outgoing call. (RFC3515 transfers require a new call to be made before transfer is effected). Recommend the maximum number of calls sent to system is 1 less then the system capacity, allowing VoiceGuide/HMP to always use the 'unused' license for the outgoing call. Share this post Link to post
bfrank Report post Posted 10/12/2010 03:33 PM OK, I will monitor for GCEV_TASKFAIL and catch the Dialogic RTF logs. Stay tuned. One question, though. The logs from 9/2/10 I posted earlier show: 151201.875 6 37 12 path {EV_TIMEOUT_HANGUP} not found 151201.875 6 37 12 HangupCall, source=LsDefaultHandlers:EV_TIMEOUT_HANGUP, WorkModeScript=Idle_WaitingForNextCall, yLineStateAppPov=[Null_InGuardTimeAfterEndOfCall], lPlayId=0, lRecId=0 151201.875 6 37 12 moduleTitle=[DoTransfer] 151201.875 6 37 12 ScriptWorkingMode set Stopping, (called from HangupCall) The [DoTransfer] module does specify paths for both {timeout 30} and {fail}, so I wonder why it wasn't followed? Furthermore, why didn't the cleanup script run for this call when it ended? It was specified as the "script to run when script ends" in the script properties. Share this post Link to post
SupportTeam Report post Posted 10/14/2010 09:49 AM Looks like any failure reports (GCEV_TASKFAIL events) from Dialogic layer during the SIP REFER (RFC3515) transfer are currently handled in a way that results in the call termination and the 'on hangup' script not being ran. We will try to look into whether in case of SIP REFER (RFC3515) transfer failure it is still OK to proceed with the remainder of he script (and hence take the 'fail' path form the module). An important factor in deciding how they can be handled would be the RTF logs from your system. When you have these available please post them here and we can then see how/if software should be modified to best handle this situation. Share this post Link to post
