jayanta Report post Posted 10/11/2010 11:07 AM Hi, We are using Voice Guide 7 and the system details are attached here in.We want to hangup the call inmmediately after disconnecting the telephone line.But at present it is taking approximately 30 Seconds to hangup the call.We have changed the following parameters in the config.xml and vg.ini file but without success :- <Parameter> <Description>Minimum Loop Current off time before it is reported</Description> <Key>DXBD_MINLCOFF</Key> <Value>50</Value> <Default>50</Default> </Parameter> <Parameter> <Description>Offhook Delay - period after offhook, during which no events are generated e.g., no DTMF digits will be detected during this period.</Description> <Key>DXBD_OFFHDLY</Key> <Value>50</Value> <Default>50</Default> </Parameter> RecCut_EndRecDueTo_ToneDisconnect=30 (In vg.ini file) SilenceDetectLength=30(In vg.ini file) Please help Regards, Jayanta sys_inf.htm Share this post Link to post
SupportTeam Report post Posted 10/12/2010 06:53 AM Most likely you need to configure the disconnect tone detection. Please read: http://www.voiceguide.com/vghelp/source/html/disconnectiondetect.htm Share this post Link to post
