Guest Guest_Alex Report post Posted 10/14/2003 06:40 AM Hi! Thanks for responses. Continue from the last email... >>If Singtel is not willing to give out this info then you'll have to use >>D41JCT and use the "Dial and Conference" option Isn't the intel D/41JCT-LS analog dialogic card? I'm already load this card. Let's me test this card tomorrow morning, GMT+08:00 7:00am-9.00am. I'm think your office hours is start around GMT+08:00 6:30am, right? Q1. So, for using "Dial and Conference" option, we still need to enter the parameter of Dial and Conference signal(hookflash) at the PBX Command Strings Page. Then, What is the actual value? Q2. Other way, if we buy the PBX System, so, the PBX System vendor will give us the parameter of Transfer Call signal(hookflash) at the PBX Command Strings Page. So, Isn't the value of the parameters are difference? Q3. Your VG dialer option package, isn't consider used if in the call flow has apply the Transfer Call Icon? Q4. There 3 telephone line was connect to the dialogic card to use your VoiceGuide, isn't need to apply the special services from my Telephone Company vendor,Singtel? Like, transfer/forward call services. Now, 2 line just the normal telephone line will hunting services, one of them was link to the Free Toll number(1800-PREPLAN). Another one line is reserve for fax out the document using WinFax. Share this post Link to post
SupportTeam Report post Posted 10/14/2003 06:48 AM for using "Dial and Conference" option, we still need to enter the parameter of Dial and Conference signal(hookflash) at the PBX Command Strings Page. No. "Dial and Conference" places a call on another line then connects two lines together, there is no need do any hookflashes. if we buy the PBX System, so, the PBX System vendor will give us the parameter of Transfer Call signal(hookflash) Yes, they should - you should speak to them about it... VG dialer option package, isn't consider used if in the call flow has apply the Transfer Call Icon? For normal hookflash transfers no, for "Dial and Conference" you need VG Dialer. isn't need to apply the special services from my Telephone Company vendor,Singtel? If using "Dial and Conference" there is no need to enable any special services on your phone lines. Share this post Link to post
Guest Guest_Alex Report post Posted 10/14/2003 07:12 AM Continue.... For Singtel (Telephone provider), it has services like : PhoneNet (See details at http://business.singtel.com/sme/products/i...t_features.asp) Feature: Linking Up All Your Offices Call Waiting Call Forward Remote Activation Call Transfer 2-Digit Speed Dial PhoneNet PhoneMail Auto Call Back 3-Way Conference OR other services (http://business.singtel.com/sme/products/international_calling_services/default.asp) need to subscript to this IVR... Thanks Share this post Link to post
SupportTeam Report post Posted 10/14/2003 07:26 AM ... not too sure what the question is here... You have mentioned before (in a separate email) that you are unable to ascertain what hookflash length is required by Singtel - which you will need to get working first if you wish to use any of the listed Singtel's services (if they are enabled on your lines).. But as I understand that your application just requires to have the incoming call connected with another number then it looks like using the "Dial and Conference" will be by far the simplest solution... And as mentioned in the previous post by us: If using "Dial and Conference" there is no need to enable any special services on your phone lines. Share this post Link to post
Guest Guest Report post Posted 10/15/2003 06:31 AM >>But as I understand that your application just requires to have the incoming call >>connected with another number then it looks like using the "Dial and >>Conference" will be by far the simplest solution... For "Dial and Conference", isn't VoiceGuide still able to track the external call timing? We much know the call spend length, start when incoming call connect to another external line and end when the connect end. Share this post Link to post
SupportTeam Report post Posted 10/15/2003 06:43 AM Call length can be calculated using the $RV_CALLLENGTH Result Variable. From VoiceGuide help file: $RV_CALLLENGTH Number of seconds since the call started. Share this post Link to post
