Shragel Report post Posted 10/31/2010 05:55 PM This settings don't work. Do i need to do something else? <VoIP_Registrations> <VoIP_Registration> <Display>CallCentric (www.callcentric.com) </Display> <Protocol>SIP</Protocol> <RegServer>callcentric.com</RegServer> <RegClient>1777#######@callcentric.com</RegClient> <LocalAlias>1777#######@10.1.1.9</LocalAlias> </VoIP_Registration> <VoIP_Registration> <Display>CallCentric 2</Display> <Protocol>SIP</Protocol> <RegServer>callcentric.com</RegServer> <RegClient>1777#######@callcentric.com</RegClient> <LocalAlias>1777#######@10.1.1.9</LocalAlias> </VoIP_Registration> </VoIP_Registrations> <VoIP_Authentications> <VoIP_Authentication> <Display>CallCentric</Display> <Realm>callcentric.com</Realm> <Identity>sip:1777#######@callcentric.com</Identity> <AuthUsername>1777#######</AuthUsername> <AuthPassword>########</AuthPassword> </VoIP_Authentication> <VoIP_Authentication> <Display>CallCentric 2</Display> <Realm>callcentric.com</Realm> <Identity>sip:1777#######@callcentric.com</Identity> <AuthUsername>1777#######</AuthUsername> <AuthPassword>########</AuthPassword> </VoIP_Authentication> </VoIP_Authentications> Share this post Link to post
SupportTeam Report post Posted 10/31/2010 07:22 PM Could you please post VoiceGuide traces capturing system startup, as well as the WireShark (www.wireshark.org) trace capturing the system startup. Please .ZIP up any files before posting them. Share this post Link to post
Shragel Report post Posted 11/01/2010 02:04 AM Here is the log Log_vgEngine.zip Share this post Link to post
SupportTeam Report post Posted 11/01/2010 05:29 AM The trace form 8Om shows that one of the registration seem to have succeeded and one seemed to have failed. We would need to see the WireShark trace to see why the registration for one of the numbers failed. We can see elsewhere in the trace that system is receiving calls routed to it from callcentric.com, so looks like the registration that does work is resulting in calls from callcentric being routed to VoiceGuide. 200031.093 5732 fn VoIPProvider_AuthenticationAdd(auth_realm=callcentric.com, auth_identity=sip:17772926376@callcentric.com, auth_username=17772926376, auth_password=******) 200031.099 5732 fn VoIPProvider_AuthenticationAdd(auth_realm=callcentric.com, auth_identity=sip:17772396560@callcentric.com, auth_username=17772396560, auth_password=******) 200031.104 5732 fn VoIPProvider_Register(protocol=SIP, reg_server=callcentric.com, reg_client=17772926376@callcentric.com, local_alias=17772926376@10.1.1.9, sH323SupportedPrefixes=) 200031.107 5732 fn VoIPProvider_Register(protocol=SIP, reg_server=callcentric.com, reg_client=17772396560@callcentric.com, local_alias=17772396560@10.1.1.9, sH323SupportedPrefixes=) 200031.109 4596 ev GCEV_SERVICERESP (board device) 200031.119 4596 GCEV_SERVICERESP ResultInfo: gcValue=1285(0x505|GCRV_INTERNAL|event caused internal failure) gcMsg=[Event caused internal failure] ccLibId=8 ccLibName=[GC_H3R_LIB] ccValue=[0x95||] ccMsg=[iPEC_REG_FAIL_insufficientInternalResources] additionalinfo=[] 200031.119 4596 ccValue!=IPERR_OK (VoIPProvider_AuthenticationSet should have been called beforehand) 200031.679 4596 ev GCEV_SERVICERESP (board device) 200031.679 4596 GCEV_SERVICERESP ResultInfo: gcValue=0(0x0|GC_SUCCESS|GC_SUCCESS) gcMsg=[success] ccLibId=8 ccLibName=[GC_H3R_LIB] ccValue=[0x0||] ccMsg=[iPERR_OK] additionalinfo=[] 200031.679 4596 ccValue==IPERR_OK (gc_ReqService registered a VoIP account) Share this post Link to post
Shragel Report post Posted 11/01/2010 12:25 PM Here is the wireshark. sip_login.zip Share this post Link to post
SupportTeam Report post Posted 11/03/2010 08:31 AM From traces it looks like you are using the single line evaluation HMP license. The 1 line HMP evaluation license only allows you to perform one SIP registration. VoiceGuide/HMP will do multiple registrations when a multiple line HMP license is used. Share this post Link to post
