Script To Run After Finishes
I would like to know if i have a script to run after a call has finished on 1.vgs for instance what would happen if one of the links voiceguide used during 1.vgs sent the user to a totally different 2.vgs script where the rest of the calls tasks were performed....
Would the script that was set to run after 1.vgs file had finished still be run or not?
Would the script that was set to run after 2.vgs file had finished still be run?
Matt
Only the "On Hangup" script for the currently executing script will be ran. If 2.vgs is the active script when call hangup occurs then only 2.vgs's "On Hangup" script will run.
