Out Dial Application
I'm using a voice modem and I'm trying to setup a simple application.
I need the application to dial a number, which is a page access code in a PBX, play a message and hang up.
I need this application to do this every day at 5:00PM.
I try to right a VB script,I use the Telephone Numbers loader and the Script Designer.
The problem is that the message is played to the end and then is played again half way.
Any suggestions?
