madnik7 Report post Posted 12/30/2010 10:24 AM Hi I think something happen to my system because suddenly the VBS module of voiceguide always execute fail path, even when i remove all code in VBS module and create empty VBS module it always lead to fail path. * I can execute VBS modules by double click * I am using voiceguide 7.0.6 I think something happen to my system so voiceguide always fail to execute VBS module. How can I fix it? Share this post Link to post
SupportTeam Report post Posted 01/01/2011 04:52 AM Could you please post a copy of VoiceGuide's vgEngine trace which captures the call, this will allow us to see what happened. Debug Trace files are be created in VG's \log\ subdirectory. Please post the traces and the VoiceGuide script used. When posting traces/scripts please .ZIP them up and post them as attachments. Share this post Link to post
madnik7 Report post Posted 01/01/2011 05:21 AM I found the issue i add the following line and it start to work vg.Run_ResultReturn $RV_LINEID, "success" But i am ENSURE it work for 2 year, and i even had 700 backup of it (daily backup). i saw the VBS module never had such line in last 2 years but suddenly from some days ago it stop working and need this line. Also empty VBS module doesn't work without that line. (I didn't test empty VBS before) I just reply it for other users. Thanks Share this post Link to post
SupportTeam Report post Posted 01/01/2011 06:24 AM In order for the Script module to go down the success path you need to explicitly return a success type result. If no result is returned the module will go down the fail (or timeout) path. A module with no script in it will go down fail path. Share this post Link to post
