allstatesmed Report post Posted 01/02/2011 01:57 AM I would like to be able to call a person 3 times and leave a voicemail each time. On the third time, I would like to export the phone number to a text file to have as a log. I have a VBS which exports the call to a log and this DOES work: Const ForReading = 1 Const ForWriting = 2 Const ForAppending = 8 set fso = CreateObject("Scripting.FileSystemObject") set tsFile = fso.OpenTextFile("c:\output.txt", ForAppending, True) tsFile.WriteLine "$RV_CIDNUMBER, $RV[OUTDIAL_CAMPAIGNNAME] ***Testing Supply Call**** $RV_STARTTIME, $RV_CIDNAME, $RV_DNIS, $RV[OutDial_Result], Times per day: $RV[input_Test_Frequency], Insulin Answer: $RV[insulin_Input]****" tsFile.Close set tsFile = Nothing set fso = Nothing ------------ The problem I am having problems with is adding the phone call to the queue. I created a VBS script but the call is not added to the queue: -------- set vg = CreateObject("vgServices.CommandLink") sTelNumber = "18133407115" vg.Dialer_OutDialQueAdd CStr(sTelNumber), "", "2010-12-29 9:00:00 AM", "9:00 AM", "9:00 PM", "", "1", "TestAddAgain", 1, "C:\Program Files\VoiceGuide\Scripts\AR-EXPRESS\Testing Supplies\TS-Responses-Human-test write to log.vgs", "c:\CallBackDetails.wav", "", "c:\ifNotAnswered.vbs", "c:\ifRetriesExhausted.vbs", 90, 2, 30, "[CustomerID]{44563}", "", "" set vg = Nothing -------- What should I change in this script? Share this post Link to post
SupportTeam Report post Posted 01/02/2011 05:28 AM Are you using VoiceGuide v7? Please post the vgEngine trace capturing the .Dialer_OutDialQueAdd call, we can then see what is happening on the system. Share this post Link to post
allstatesmed Report post Posted 01/03/2011 02:14 PM Yes, using VG7. Please see the attached vgengine file. 0103_0841_vgEngine.zip Share this post Link to post
SupportTeam Report post Posted 01/03/2011 07:28 PM Trace shows: 085046.562 22 Dialer_OutDialQueAdd [18133407115], [], 2010-12-29 9:00:00 AM, 9:00 AM, 9:00 PM, DaysAllowed, LineSelection=1, CampaignName=TestAddAgain, Priority=1, OnAnswerLive=[C:\Program Files\VoiceGuide\Scripts\AR-EXPRESS\Testing Supplies\TS-Responses-Human-test write to log.vgs], OnAnswerMachine=[], OnAnswerFax=[], OnNotAnswered=[], OnRetriesExhausted=[], 90, 2, 30, RV=[CustomerID]{44563}, CallOptions=, Escalation= 085046.562 22 ERROR: COM interface not supported in this version. It looks like the license used on this system is not an Enterprise license. You must have Enterprise license to use WCF/COM/Remoting interfaces. Share this post Link to post
