Integration Question
Is it possible to do the next: ?
A customer makes a call or send a SMS indicating his ID and a code to get same information (Ex: 1-Debt, 2-Next expiration date, etc)
The VoiceGuide must be able to access On-Line to diferents DBMS to validate the ID
If the ID is not correct, return a message voice or SMS with the error
If the ID is correct, return a message voice or SMS with information save on the DBMS like debt for example.
What happens if the DBMS is not running ? Is it possible to define a timeout and a message voice / text for this case ?
Do you have customers in Argentina ? In the possitive case will be important to konw who to contact with them to know about their experience using the software / service.
Thank you
Eugenio
Retrieving data from databases and acting on it (or reporting that database is not contactable or not responding) is fairly straightforward.
VoiceGuide can be used to answer incoming voice calls and accept caller's selections, and play responses to them.
Yes.
Sounds like you haven't downloaded and tried the evaluation version of VoiceGuide. You can use the evaluation version of VoiceGuide to set up and test out your system. You can install it in VoIP mode, which does not require any cards etc to use.
If you want to handle a SMSs then you would need to get an SS7 connection or have some other setup that delivers SMS to you (eg. over IP etc).
Over what channel do you intend to receive SMSs?
We have customers in Argentina (we have thousands of sites world wide).
Please contact sales@voiceguide.com and indicate what size system you intend to deploy. Some appropriate referees can then be forwarded to you.
