Guest dadozach Report post Posted 01/26/2011 09:34 PM I am not a VB coder, but can easily understand your scripts. Using your outbound calling feature, it is possible to chain audio files together on the fly? Such that I might record the sentence “Hi, this is a message for” and then based upon the data in field pull in another audio file. For instance, if the data was “Bob” the recipient would hear “Hi, this is a message for Bob,” followed by the remainder of the outbound message. I would record every name in my own voice (not use text to voice). This way each message would be personalized. Thanks, Dadozach Share this post Link to post
SupportTeam Report post Posted 01/27/2011 07:10 AM Yes, it is possible to chain the sound files. Just specify the sound files one after another, separated by commas. You specify the sound files to play in a Play module in a VoiceGuide script, and then specify that script as the script to use when the persona answers the call. Best to specify the full path to the sound files. see: http://www.voiceguide.com/vghelp/source/html/modplay.htm Share this post Link to post
SupportTeam Report post Posted 01/27/2011 07:12 AM In your script you can use an $RV and set that $RV to hold the personalised filename. $RVs can be specified at call load time. see: http://www.voiceguide.com/vghelp/source/html/resultvariables.htm from http://www.voiceguide.com/vghelp/source/html/diallistinto.htm : Result Variables Result Variables can be supplied to be used by the scripts ran during the outgoing call. The format of this field is [RvName]{RvValue}. Multiple Result Variables can be specified by listing as many name-value pairs as needed. eg: [rv1]{val1}[rv2]{val2}[rv3]{val3} Share this post Link to post
